The new switch is probably not the same size as the old either and you'll probably need to modify the housing a bit to make it fit. As for the wiring, it really doesn't matter which goes to which terminal since it's just an open/close set of contacts.
Barrpete, thanks for responding! Thats clear ive got everything cut and shimmyed and the wire tube thru the fire wall just needed to know where which wire went, and now i know it doesnt matter....Preciate ya....Damian
