-   -   Help with wheel lug lock issue (http://forums.pelicanparts.com/porsche-911-technical-forum/616767-help-wheel-lug-lock-issue.html)
marcsalleras 06-30-2011 07:29 AM
I have an 86 911.....have the one lug lock on each wheel with the OEM locks on it (kind that are just cylindrical all around and slide over the lug itself so no socket can fit over it with the key hole on the face of the lock)....Was down in florida a little while ago and someone stole my keys which had the key to those on there.....now someone hit my front left fender and I'm about to go have it taken off and have a new painted one put on but part of that process is removing 6 nuts in the wheel well which would be easier with the tire off...........any idea how to get the locks off? anyone ever tried picking them....or maybe cutting the heads off? or are all the keys the same for those locks so maybe i should look for another pelican with a key orrr? Up **** creak without a paddle.
porschenut 06-30-2011 09:00 AM
If there are 6 nuts in your wheel well then one of them must be you. ;)
A carefully targeted hammer blow ought to remove them with little drama. The ones I had could be removed with my bare hand. I found them to be useless.
Joe Bob 06-30-2011 09:07 AM
Use a sacrificial, slightly oversized socket. Jam it/pound it on pull the nuts.
JohnJL 06-30-2011 09:20 AM
Many garages have sets of these locks just for this purpose...
vracer 06-30-2011 10:20 AM
The garage that did a PPI for me said it took longer to walk to the toolbox to pick up a slidehammer than to remove the cover. There is a tall conventional hex lug under it.
john walker's workshop 06-30-2011 10:47 AM
they are pretty easy to kill and remove. i use an air hammer and a chisel bit. face mask/gloves. just shear the flanged top off. aim away from the wheel parts.
tonythetarga 06-30-2011 11:20 AM
if you prefer to keep the locks intact, have a locksmith come over and make you a key.....and a spare :D
marcsalleras 07-01-2011 04:49 PM
So options are hammer it head on, cut off the face of it, or get a locksmith involved..............time to break **** gentlemen. Appreciate the help.
porschenut 07-01-2011 08:04 PM
I recommend a side blow. A light tap may be all that's needed. If not, tap a little harder.
newms 07-01-2011 08:21 PM
you can also drill out the 'lock' in the center in about 3 seconds then the cap slides off
marcsalleras 12-25-2011 09:32 PM
drilling it out took about a minute and 30 per lock, did it with an electric drill and average drill bit...thanks gentlemen
JJ 911SC 12-26-2011 02:53 AM
+ 1
Did that on a broken lock on the wife civic
ejp 08-12-2012 07:29 PM
So if all that's required is a single blow with a hammer - are the locks even worth it? I'm considering pulling mine and buying a few OEM lugnuts for a cleaner look.
Joe Bob 08-12-2012 08:08 PM
Wheel locks are a waste of time.....
JJ 911SC 08-13-2012 02:11 AM
and $$$
