LED Test Light
I found in a Bentley manual how to build a LED test light that is safe to use in electronic circuits.
The only drawback is that it is polarized, meaning if you connect it wrong it will not light.
that is why I used a red wire for the positive voltage.
With a needle tip
Old 06-30-2011, 12:06 PM
dshepp806's Avatar
Which section of the Bentley is this located ?
THANKS!
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 06-30-2011, 01:09 PM
one of gods prototypes
bell's Avatar
i've made many of those.......a little trick is to fit it into a pen with the led at the top and a pointy probe out the tip
Brought to you by Carl's Jr.
Old 06-30-2011, 04:49 PM
Doyle
It is in the GTI Golf Bentley manual, not in the Porsche manual.
Old 06-30-2011, 05:35 PM
rnln's Avatar
why not just use a multimeter?
Fat butt 911, 1987
Old 07-01-2011, 01:27 AM
bell's Avatar
i have a fluke 87 and one of these.......
Amazon.com: Power Probe III Ultimate 12 to 24 Volt Automotive Electrical Circuit Tester Kit: Automotive
best electrical tool i've ever used for troubleshooting......
Old 07-01-2011, 10:03 PM
db_cooper's Avatar
The nice thing about an LED over a VOM is you can see the pulses..it is very clear if you have an issue.
Speed or reference sensor..fuel injector...no doubt if in five or ten seconds of cranking the engine over if the pulses are irregular, missing or weak.
Old 07-02-2011, 09:00 AM
