LinkBack | Thread Tools |
Rating:
WWEST
Does a SPAL fan cool your 911? Why do you so easily take a single case and use it to fit your theory about something else that is far from even similar. Sounds like you need to do some testing before making assumptions. After all, you really cant challenge the engineers at Porsche without some proof. can you? Quote:
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling. |
Proof..? Doesn't the linked post do the job..? |
Yes I saw post 734. and?
if there is conflicting info (seemingly) between some SPAL models where curved = less volume and on other models where it = more volume... wouldnt it make sense to find out why before making assuptions about the Porsche fan which is not even the same design as SPAL nor made by SPAL.
Banned
Straight vs. Curved Fan Blades - Dispelling the Myth! Note that with the 964 Porsche did exactly what is talked about as a negative in that linked webpage - curved the blades and kept the shroud struts straight = big loss in moved air volume. Last edited by Ronnie's.930; 06-26-2013 at 10:42 AM.. |
Nice write up and research.
Of course WWEST will claim that anything tested on the bench isnt valid. LOL If he accepted this, he would need to accept Griffiths bench testing... and we couldnt have that. That blows up his whole purpose in life. LOL he will also claim that its false and just snake oil because the research was done by someone selling something... to accept this would expose his double standard when it comes to GTI. of course those standards dont apply to SPAL since he bought their snake oil. Quote:
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling. Last edited by brads911sc; 06-26-2013 at 10:50 AM.. |
they are just selling snake oil.
cant trust that bench testing. Quote:
Oh, the naysaying..where is the power draw chart and/or relative RPM between the 2, for one vs the other..? Last edited by wwest; 06-26-2013 at 11:07 AM.. |
Why ? because you paid money for the snake oil?
SPAL could never lie. I own those. LOL so predictable WWEST.
Banned
Question - if the 964 curved blade fan moves more air, as wwest claims, why do you suppose Porsche put the straight blade fan on the 964 turbo which generates far more heat than the non-turbo 964? Do you think it was because Porsche wanted it to run hotter and thus promote even more frequent engine overhauls?
WWEST operates from a SPAL fan snake oil perspective. not one based in logic or fact. so doubt you will make him understand what you are saying... this stuff is just too complex for him to comprehend.
Banned
Right - it's not every day that your run across someone that ignores facts and/or logic simply because they are trying to save face in a discussion over something as simple as fan air volume.
truly unbelievable. you should see his posts over on another thread. just as crazy and insane. over there the entire premise is about engine heat. AC is secondary. the guy doesnt even have AC yet... turned the entire thread into a Spal fan and trinary switch discussion. LOL
Pre AC project - getting the car's temp down!! pretty entertaining...
---------- Forwarded message ---------- From: A1 Electric Date: Wed, 26 Jun 2013 11:50:02 -0700 Subject: RE: A1 Electric Email Form To: wwest Yes, going by the current numbers that Spal has published, it appears that the curved blades perform better. A1 Electric Automotive Accessories 2301 W 205th St Ste 101 Torrance CA 90501 (888) 838-0506 (310) 328-8500 A1 Electric Automotive Accessories, Power windows, Power door locks, keyless entry systems, Window motors, Window regulators, Pop door kits -----Original Message----- From: wwest Sent: Wednesday, June 26, 2013 11:10 AM To: info@a1electric.com Subject: A1 Electric Email Form Below is the result of your feedback form. It was submitted by wwest on Wednesday, June 26, 2013 at 14:09:37 --------------------------------------------------------------------------- Name: wwest Vehicle: 1988 Porsche 911 Comments: Your FAQ answer "sacrifice a small performance level for/with curved blade fans vs straight blade fan does not appear to hold true for the clear majority of your products.... Very puzzling...Spal's own numbers. It appears that Spal's "small sacrifice" rule does not apply in all cases. 30102041 pull/straight 1434 CFM 19.5 Amps 30102042 pull/curved 1864 CFM 17 Amps 30102055 push/straight 1333 CFM 19.5 Amps 30102056 push/curved 1841 CFM 17 Amps More airflow PLUS lower power draw. --------------------------------------------------------------------------- |
Lol Snake oil. Sales pitch doesnt match their FAQ. Snake oil.
No one cares WWEST. This is a Porsche Forum not a SPAL forum! Put this with the lexus and ford references. as an aside... If the same thing happened on GTI site (like the hose argument you sited). you are all over it. whats with the double standard? Quote:
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling. Last edited by brads911sc; 06-26-2013 at 12:57 PM.. |
Banned
Banned
I would suppose that with the higher efficiency of the curved blade fan spinning it at the speeds required to cool the turbo resulted in "compressor stall" or as some would say, "cavitation". At what speed relative to the engine does the 964 turbo spin the fan..? |
Note: "Stalled Condition"
