-   -   alternator rattle problems? (http://forums.pelicanparts.com/porsche-911-technical-forum/617210-alternator-rattle-problems.html)
9112.2t 07-02-2011 10:01 PM
Hi everyone I have a 911 w/ 2.2 and the alternator is starting to rattle. It has a Bosh 55amp external reg. I removed the belt and the rattle went away. So I removed the alternator and fan from the housing thinking it might be the barrings. There was no drag or noticeable play in the shaft up down in out? I noticed that I only have 3 shims. 2 inside 1 outside. Reading the threads do I need 6 shims? All help is greatly appreciated.
Thank You Bob.
DRACO A5OG 07-02-2011 10:07 PM
on the 3.2 one needs 6.
Driver_X 07-03-2011 04:19 AM
I had a similar problem, it's your lack of shims.
It can lead to all sorts of problems....
Info here: http://forums.pelicanparts.com/porsche-911-technical-forum/232018-pulley-shims-wrong-config.html
My thread: http://forums.pelicanparts.com/porsche-911-technical-forum/610056-pulley-alignment-question.html
9112.2t 07-03-2011 09:58 AM
Bad news, The Fan is notched and the pulley. can I weld in the void then mill/ machine down to a flat surface on the fan?
http://forums.pelicanparts.com/uploa...1309712154.jpg
http://forums.pelicanparts.com/uploa...1309712259.jpg
