stuck bolts
i am trying to remove my side windows on my72 targa but the hex nuts have been rounded so i cant get them out they are located at the side of the door and only reached through a round hole so i cant get a pair of pliers on them any ideas
Old 08-20-2011, 01:51 PM
schumicat's Avatar
force (hammer) on a cheap SAE socket and remove with extension and ratchet. you may not be able to get the nut out of the socket so use a cheap one.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off.
2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver)
Old 08-20-2011, 02:25 PM
Brown747's Avatar
Screw/bolt extractor
Craftsman has a set of screw/bolt extractors that may do it for you. I as able to remove a broken head stud from my case with one. Set comes in 5 sizes.
Craftsman 5 Pc. Power Bolt-out Set - 52168 Reviews | Buzzillions.com
HTH Thor
1978 SC coupe #1834
Old 08-20-2011, 03:17 PM
masterdave's Avatar
For stuff like that, i like to get a small drill bit and bore out the center, then with the bit still in there but the drill in reverse with enough PB blaster the bolt may come right out. If it does not remove the bit and try and get a metal pole stuck in there, say a small screwdriver or some thing and twist it out.
Best of luck
Dave
David Colangelo
"Porsche Accept No Substitute"
78' 911 Targa
88' 924s
31' Ford Model A
Old 08-21-2011, 06:41 PM
