Home of the Whopper
How to mount tire rack in trailer?
I need to hang a tire rack inside of an enclosed trailer.
I have seen carriage bolts from the exterior through the entire stud, sheet metal screws into the stud, and screws into those plastic thingies. I have also seen several tire racks fall.
What is the best, safest way?
Thanks,
BK
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller
Old 07-06-2011, 03:30 PM
Danny_Ocean's Avatar
No to sheet metal screws. No to "plastic thingies". Thru-bolts only on a supporting member (or add a backing member attached to a supporting member).
Old 07-06-2011, 03:39 PM
Platinum Member
dad911's Avatar
I've seen vertical supports added, and the rack bolted/welded to that. Also seen guys using "E" track on both sides, with shoring/cargo bars as the rack.
Personally, I like to store tires low, strapped to the floor, with a PVC pipe run through the center.
Old 07-06-2011, 03:46 PM
