-   -   Backdated heat and A/C......... (http://forums.pelicanparts.com/porsche-911-technical-forum/617815-backdated-heat-c.html)
fred cook 07-06-2011 02:22 PM
Can air conditioning be used on an engine that has had the heat backdate done on it? I am getting ready to build and engine for my SC and would like to do the heat backdate AND keep the a/c.
Thanks,
Flat Six 07-06-2011 02:45 PM
IIRC, most heater backdate involves:
1) Removing the engine-mounted auxiliary blower, and relying on only the footwell blowers instead.
2) Also may involve introducing additional resistance in the footwell blower circuit (formerly supplied by the now-removed engine bay blower) to make sure the FW blowers operate correctly.
3) Changing the air duct on the driver side (LHD) of the engine fan to direct more air over the driver-side bank of cylinders.
4) May also involve (depending on HEs installed, model year, etc.) re-routing/replacing hot-air hoses.
All of this is independent of the AC system, so I don't see any reason why you can't do both. But not having done it myself, perhaps someone who has done it can chime in with some helpful hints for you?
Good luck Fred. HTH
Dale
Neel 07-06-2011 02:51 PM
^+1..
KNS 07-06-2011 03:40 PM
I had a 1980 SC that I backdated the heat - so glad I did. The AC will work just fine without the extra heating bits...
tcar 07-06-2011 03:45 PM
The A/C and the heating system on the 911 SC and earlier are totally separate. Ditto thru '89.
Neither affects the other.
You can totally remove the heating system and keep the A/C (and vice-versa).
He11, the ventilation system is almost separate too.
Integration? Nah.
fred cook 07-06-2011 03:57 PM
Need to know......
What I was concerned about was fitting the right side hose under the a/c mounting bracket. I had read somewhere that the block off plate tube on the passenger side would interfere with the a/c mount.
Bob Kontak 07-06-2011 04:04 PM
I got the piece from PP and had no problems fitting it. Went right under the AC bracket on my 81. It's been a while - maybe a tap or two with a hammer to make clearance. The driver's side from PP was the PITA. I thought it would be the reverse like you. Search on posts - some say the driver's side fits great. Not my experience.
Bob Kontak 07-06-2011 04:06 PM
Does the 83 have footwell blowers?
schumicat 07-06-2011 04:11 PM
no, I believe that started in 84 with the Carrera.
Bob Kontak 07-06-2011 04:14 PM
D911SC 07-06-2011 04:22 PM
Don't think so. Mine certainly doesn't. I thought these came in 84-
EDIT - beat me to it schumicat!
JJ 911SC 07-06-2011 04:38 PM
No blower for sure...
I just finished the heat backdate after I put the SSI. My AC is already deleted so I can not speak of the right side but even without putting my distributor on, I know that the left side will need some convincing as in beeing ballpeened as per Bob finding.
Extrack from; http://forums.pelicanparts.com/porsche-911-technical-forum/614974-ssi-heat-option.html
... Moving right along as fast as a http://forums.pelicanparts.com/support/smileys/wat3.gif
With the help of DW SD (post 52 of http://forums.pelicanparts.com/porsche-911-technical-forum/220695-why-you-should-backdate-your-heat-3-2-a.html) I converted the side tin to allow the hose to go through.
I bought the 2 holed square pieces, overlap them on the original side pieces. Mark where to cut and drilled, did a "fast" paint job, installed the hose and voilas;
Still have to installed some nice looking hose clamp.
http://forums.pelicanparts.com/uploa...1309945407.jpg
http://forums.pelicanparts.com/uploa...1309945546.jpg
http://forums.pelicanparts.com/uploa...1309945581.jpg
http://forums.pelicanparts.com/uploa...1309945614.jpg
http://forums.pelicanparts.com/uploa...1309945668.jpg
http://forums.pelicanparts.com/uploa...1309945731.jpg
http://forums.pelicanparts.com/uploa...1309945794.jpg
http://forums.pelicanparts.com/uploa...1309945928.jpg
http://forums.pelicanparts.com/uploa...1309946100.jpg
Canada Kev 07-06-2011 04:53 PM
Looks great. Where did you get the holed square pieces?
JJ 911SC 07-06-2011 05:10 PM
Thanks. On PP used part forum while doing a search for "engine tin". Came all the way from Hawaii.
I'll check with someone else that show me a picture that had then on it (not sure if they were for sale) and I'll let you know.
