Flywheel Mods / Clutch Question
After a recent infusion of cash, I am finally in a position to get the parts together to swap in the 2.7 liter motor into my '69. It is a mild motor with Webers so the 901 gearbox (I like the old shift pattern) is staying. I am planning am planning on using the stock 215 mm flywheel and a Kennedy Engineering Stage 1 clutch to deal with the extra torque.
Has anyone done any modifications to the flywheel to lighten it and if so: (1) was it worth the effort and (2) is there a shop in the SoCal (preferably San Diego) area that you could suggest to do the work?
Second, does anyone have experience with the Kennedy Engineering clutches?
Thanks in advance,
Rich
Old 02-26-2002, 04:19 PM
keitho64's Avatar
Gee, an infusion of cash? Hmm... where from?
I am anxious to hear how the 2.7 works out for you. I can't help much on the clutch request but if you are going with the 2.7 should you use an aluminum flywheel? If you do not intend to drag race it (which I know you won't) I would thing the lighter flywheel is worth it.
I will look up a few Corvair vendors who are out your way. One is Larry's Corvair in LA area http://home.earthlink.net/~k6ro/ if he cannot help I bet he can point you in the right direction. Another possibility is Ray Sedman at http://www.american-pi.com/corvair/corvhome.html once again he is Corvair but I am sure he could provide some leads.
Good luck.
Keitho64
05 GTO
00 911 C2
64 Corvair
Chicago Burbs; the Anti-Dragon... 11 turns in 318 miles
Old 03-05-2002, 07:38 PM
jluetjen's Avatar
BTW: Steve Weiner at Rennsport also does lightweight flywheels and clutches for early cars. You might want to talk to him at 503-244-0990. He has a good reputation and the UPS up and down the coast can't be that bad.
- John
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 03-06-2002, 05:43 AM
