ok.. here is a really dumb question. last night I was making final connections on my motor. Their is a braided ground strap that is located in the engine compartment, the one that is attached to a stud with a couple of other ground straps next to the fuel accumulator. Well, where on my motor does the braided strap with the ring lug attach too? I'm stumpped.
Thanks Guys Jorge (Targa Dude)
Senior Member
I don't have ground straps in my fuel accumulator area. Just one big strap between the tranny nose and the body, under the car on the passenger side.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
Is it the strap that connects to the rear deck lid, at the driver's side hinge?
Bill Krause We don't wonder where we're going or remember where we've been. |
I'm w/wckrause on this one. Also, braided ground straps are more efficent, IMO.
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Deck lid.
There are three specific braided ground straps that I can recall in the engine compartment:
1. From the engine cover to the body. 2. From the alternator frame to one of the engine top row of M8 case DIN 985 Nylock nuts. 3. Under one of the M6 Allen bolts mounting the CDI-unit to one of the mounting bolts for the relay plate to the body at the fender ... a bare sheet metal spot -- masked from painting to provide good electrical grounding for the relay plate and all of its' electrical circuits!
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
Thanks guys.. I know its not the the deck lid ground. I didn't have to remove those to drop the motor.
I know it's not the Alternator ground, and it's not my CDI Ground That leaves the the Engine cover to Body ground. Warren, do you mean Engine Shroud? and if so can I use one of the rear mounting bolts on the drivers side? Thanks again.. Jorge ( Targa Dude)
Jorge,
Engine cover = deck lid ... the EMI/RFI shielding strap
Thanks... I'm not sure I'll have to check it out when I get home..
I re-did this strap when the engine was out. Part of the engine bay cleaning painting process now I can just cant remember where I disconnected it from. I could have sworn it was attached to the engine some place. that may explain why I cant seem to find a obvious attach point on the motor. Thanks all.... Jorge (Targa Dude)
