-   -   Gearbox 915 (for 3.2 series): how many types of 915 gearbox? (http://forums.pelicanparts.com/porsche-911-technical-forum/618053-gearbox-915-3-2-series-how-many-types-915-gearbox.html)
dan67 07-07-2011 09:57 PM
Hi!, i'am Danilo from Italy (sorry for my bad english)
please, how many types of 915 gearbox on 3.2 body? (i have 915/67 Euro)
(eccept models CH/JAP(short gear..i suppose) or catalized models)
I read in an old italian magazine on middle 85 the 915 change on 915/72? (good 1°sincro and shift, and other small improvements)
livi 07-07-2011 11:40 PM
Between 1984-86 there were six 915 iterations:
915/67
915/68
915/69
915/70
915/72
915/73
dan67 07-08-2011 01:01 AM
wow! six gearbox type!
Peter Zimmermann 07-08-2011 06:50 AM
/67 = '84 RoW
/68 = '84 USA/Japan
/69 = '84 Turbo Look RoW
/70 = '84 Turbo Look USA/Japan
/72 = '85/86 RoW
/73 = '85/86 USA/Japan/M 298
All units were 5-speed.
GH85Carrera 07-08-2011 07:04 AM
Were the differences just the gear ratios?
dan67 07-08-2011 09:54 AM
thanks! but please difference 915/67 vs 72 ?
Peter Zimmermann 07-08-2011 09:54 AM
The /67, /69 & /72 had the same ratios, and the /68, /70 & /73 had the same ratios. All units had the 8:31 final drive. The two '84 Turbo Look transmissions were fitted with 108mm diff flanges that were compatible with Turbo axles/CV joints. All '85/86 915s were fitted with 108mm diff flanges; they were set up to work with both Turbo Look models and regular narrow-bodied Carreras.
Peter Zimmermann 07-08-2011 09:59 AM
Both of those units were fitted with the same internals, except axle flanges, and both were RoW units that had external oil cooling. The /67 had 100mm diff flanges, the /72 had 108mm flanges. The small and large flanges can be interchanged.
donporfi 07-08-2011 10:22 AM
Which ones did have an LSD ?
carrera84 07-08-2011 11:34 AM
With or without oil-cooler, ratios...
Differences are listed here
Google-Ergebnis für http://www.pocg.eu/pages/technik/911/images/915_getriebe.jpg
Peter Zimmermann 07-08-2011 12:17 PM
LSD was optional, and designated by the number "12" stamped into the housing at the serial number.
