-   -   Battery keeps getting drained (http://forums.pelicanparts.com/porsche-911-technical-forum/618179-battery-keeps-getting-drained.html)
privatepang 07-15-2011 08:12 PM
Ok thanks guys. Appreciate the tips. Will see if i can trace the pumps. Its annoying as on my car its behind the rear driver side quarter panel.
DRACO A5OG 07-15-2011 08:15 PM
Oh my :eek:
H-viken 07-16-2011 12:22 AM
Originally Posted by Mitch Leland (Post 6125011)
You don't have an after market alarm system installed in the car do ya?
A lot of alarms engage the turn signals. Maybe the PO only pulled the alarm half way? I.e took away the horns so it is silent. Removing an alarm can be a pain if you don't know what you are doing, especially if it had the immobilizer installed.
privatepang 07-16-2011 11:17 AM
But wouldnt the cables be attached to the battery posts if I had an alarm? I tried disconnecting those and it didnt make a difference?
Car was driving fine for hte last few months so just random that its doing this now.
a week ago i remember reading the battery at 9Volts so it still had juice then it got drained to 0.5 volts over a few days so there was defitnely a drain but the pump wasn't turning on...only when i attached it to a jump lead source it started doing that so I must have done something... i did check the horns and maybe plugged the leads into the wrong sockets on the horns.. i'll give that a shot next
86 911 Targa 07-16-2011 12:12 PM
Drained Battery.
As per the previous post, lifting fuses, and other ideas is a good beginning.
If your car has/had an after market alarm system, this may well be the issue.
I have helped other P-Members with this identical issue, which, in many cases led to a defective/alarm system.
Here is a link which for your model/year electrical diagrams.
Manuals
You may pm me as required.
Good luck,
Gerry
privatepang 07-16-2011 12:48 PM
Ok got another update
Had a play ard again.
Few funny things now. Firstly I dont think its the fuel pump, I heard a whirring sound and assumed it was but it wasn't.
Its the 14 pin connector in the engine bay. Checked voltage and there was 12V coming from pins 14 & 11 even when the car is turned off. So a few electrics stay on if the car is turned off if the14 pin connector is connected...
Thought it may have been the 3 fuse panel i installed and maybe the wires i connected to each post may have been wrong but I tried taking out the fuses and it didnt make a difference.. Checked back of fuse panel and its 25 25 5 (3-2-1) so i changed the last one. Didnt make a difference.
Found the wire attached to the distributor was also disconnected(must have knocked it loose when checking the cap and rotor) so I connected that back up.
Tried starting the car for the hell of it and it did start up but ran like ****. Kept backfiring so turned the ignition off but the car kept running! Had to disconnect the 14pin connector to turn the whole car off.
So thats where I stand at the moment... welcome anymore tips.
privatepang 07-16-2011 01:02 PM
Ok found this. http://forums.pelicanparts.com/uploa...1302701382.jpg
So makes sense why the car wouldnt turn off as 14 & 11 is Starter and Alternator. Hopefully i didnt screw up the alternator by unplugging the 14pin connector....
ipacketeer 07-16-2011 01:08 PM
If your alternator/regulator not producing 14.1 - 14.7 volts to charge your battery and provide enough juice for the operation of the car, electrical demand of the running car will discharge a good battery. Alternator and or regulator must be tested to make sure that problem does not lay there.
privatepang 07-16-2011 01:15 PM
Well my main issue right now is that when the car is not even on, a few electrics are working...
Need to work this issue out before i even look at the battery recharge...
privatepang 10-24-2011 09:35 AM
Ok just to finish off this thread.
Brought it to a fellow pelicanite wrench here in Van and he was able to help me troubleshoot the issues.
Ended up being 2 things. First was the alternator needed a rebuild. Once that was done, still had to troubleshoot the constant power even when the ignition was off and that was caused by a faulty headlight switch. This was replaced and now my electrical woes are fixed! YAY!
dshepp806 10-24-2011 01:40 PM
What was the specific failure of the headlight switch?
Best!
Doyle
privatepang 10-24-2011 01:50 PM
Not quite sure to be honest. Think it was causing an open circuit so would just have constant draw on the battery.
SC-targa 10-26-2011 10:42 AM
Sounds like a diode is failed in the alternator. That will drain the battery.
Need a new alternator, or rebuild your existing unit.
Quick check. If you can charge the battery enough to start the car. disconnect the ground from the battery. If you tap the ground cable against the neg pole of the battery and you get small spark, you have something draining the battery.
Nothing else should be powered to draw that much current.
privatepang 10-26-2011 11:19 AM
Yeah that was all done and issue is fixed(as above). Thanks for the tips tho.
