jamesjedi's Avatar
Fiberglass Bumper Intall??????
My Ruf replica REAR bumper does not have mounting brackets. Do I simply bolt it to the body panels?
I seached for about an hour, did not find anything conclusive.
Any help would be appreciated. THANKS!
Old 10-16-2011, 01:51 PM
abit off center
cgarr's Avatar
Yes, On the back side I just went up thru the bumper top into the metal tin with some screws that runs under the rear reflector.
______________________
Craig
G2Performance
Old 10-16-2011, 03:07 PM
jamesjedi's Avatar
Thanks for the help. I searched for some time and did not find many specific answers.
Did you use sheet metal screws? Have they ever become loose?
I may use nuts and bolts if I can make them fit.
Old 10-16-2011, 04:49 PM
abit off center
cgarr's Avatar
I use small bolts along the body where I could get to them. One bolt I had to remove the tail light bucket to get in there. The upper back I used sheet metal screws with hex heads, 3 of them I think.
Craig
G2Performance
Old 10-16-2011, 05:06 PM
jamesjedi's Avatar
Thanks for the information.
Old 10-26-2011, 10:33 AM
175K911's Avatar
Pretty much the same when I mounted my Yellowbird rear. I think I've got 7 or 8 bolts and screws holding it in place. The one thing I did in addition is that just inside of the wheelwell opening I drilled and added a bolt to get the end of the bumper to line up with the flare perfectly. Oh, and it was a lot easier with the muffler off the car too as I recall.
Ed
'86 911 Coupe (endless 3.6 transplant finally done!)
'14 Jeep Grand Cherokee 3.0 Turbodiesel (yes they make one)
'97 BMW 528i (the sensible car, bought new)
'12 Vintage/Millenium 23' v-nose enclosed trailer
Old 10-26-2011, 11:20 AM
