cleaning Fuchs wheels
Does anyone know of a magic cleaner that will remove 23 years or brake dust and road grime from the backside of my Fuchs wheels. I doubt these have ever been cleaned before. I have tried purple cleaner, brake cleaner, 3M adhesive remover, diesel and carb cleaner with little effect. They are still a nasty gray/black. I am not even sure what the backsides should look like when properly cleaned. Does anyone have a good picture of the backside of a well cleaned Fuchs wheel?
Old 07-15-2011, 06:50 PM
Pressure washer?
Old 07-15-2011, 07:03 PM
Red Clubbie's Avatar
Have you tried Iron X?
Cheers,
Geoff.
1984 911 Carrera.......
Old 07-15-2011, 08:40 PM
Recreational User
porschenut's Avatar
This is what a brand new Fuchs wheel looks like from the factory. The back side is painted black also:
I've used a lot of different wheel cleaners and there are only 2 that I can recommend to handle that job:
1. Meguiars Wheel Brightener - this is acidic and can damage the aluminum wheels if you keep it on too long. Use with caution but this stuff is the strongest wheel cleaner you can buy according to all my research and experience.
2. Sonax Full Effect wheel cleaner - this is safe for all types of wheels but is astoundingly good. 2nd best wheel cleaner out there.
Honestly, I doubt that either of my suggestions will get those wheels perfectly clean, and from the looks of them, they're missing a lot of paint. My recommendation would be to bead blast them and repaint them with Wurth satin black spray paint. Or, take them to a refinisher and have them professionally restored.
Old 07-15-2011, 08:42 PM
WPOZZZ's Avatar
Wet sand with 300 grit.
Old 07-15-2011, 08:56 PM
I just used some Meguiars All Wheel cleaner yesterday and left it on the recommended 15 seconds and still had some of the "silver" come off at the outer rim. Not the end of the world since they will need refinishing anyway but use caution as porschenut suggests. Just my two cents.
'88 Sunroof Coupe
'95 900 CR
Garnetredcoupe's Avatar
We used Oil Flo on the the back side of our 928 wheels to remove 10 years of brake dust. It worked really well and did not damage the surface of the wheel.
Oil-Flo
Far From Stock 1985 Euro 3.2
Old 07-15-2011, 08:57 PM
Easily Confused
dtxscott's Avatar
In addition to your favorite cleaner, I usually use 0000 grain steel wool to help. It will remove a little loose paint, but will get the grime off.
Scott C.
'08 Cayenne GTS 6MT : '89 Targa GP White/Black - "Oliver's Car" : '11 Mitsu Evo X : '08 Lexus IS350 F-Sport : '01 Toyota Sequoia : 1998 Yamaha V-max : 1979 BMW R65
Old 07-15-2011, 09:28 PM
I am my 911's PO
'78 SC's Avatar
P21S Wheel Cleaner removed decades of build up from these 33 year old wheels:
Pricy, but worthwhile for a major cleaning. I haven't tried the gel, but it sounds like a good solution to caked on crud that requires a good soak. Pelican Parts.com - P21S Wheel Cleaners
Fuchs are easily damaged by abrasives or alkali cleaners, especially if you let them soak too long.
1978 SC - original owner
1983 SC - D stock "rescue" track car
DECEASED 2015 Cayenne Diesel (rear ended by distracted driver)
2017 Macan (happy wife...)
2016 Cayenne Turbo - tow vehicle and daily drive
Old 07-16-2011, 06:31 AM
Make Bruins Great Again
Por_sha911's Avatar
P21S Gel is great. Specially formulated to remove brake dust (worthless on oil/grease). I use it on white wheels. PH balanced so it won't destroy the paint or anodizing on your wheel. Spray it on a dry wheel, let sit for a minute, gently brush it-no need to scrub and then rinse.
I use an old plastic shower puff that I stole from my wife:
Joe
Old 07-16-2011, 04:08 PM
Formerly known as Syzygy
Canada Kev's Avatar
Uh huh, from your wife...
Kevin
Old 07-16-2011, 05:48 PM
I just used Eagle 1 safe for Aluminum cleaner and a soft brush. 2 applications and they were spotless. Cleaned them for new tire install. Before cleaning they looked like they had never been cleaned before. I bought another bottle.
Old 07-17-2011, 10:09 PM
On Tour
MMiller's Avatar
I cleaned mine up with Simple Green.....I was surprised how well it did.
Old 07-18-2011, 06:42 AM
One thing with Simple Green is that it corrodes aluminum. My understanding is it has to be on the aluminum for a long time for that to happen, and the Fuchs are anodized, but I'd wash with dish soap afterwards.
1986 911 Carrera Coupe
2016 VW Golf R
2008 Toyota Highlander (given to kid)
2021 Kia Telluride
2020 BMW R1250RS
Old 07-18-2011, 06:47 AM
On Tour
MMiller's Avatar
Interesting....
Was not aware of that.....It was not on there long and was well rinsed afterwards but still nice to know.
Simple Green and Aluminum Frequently Asked Questions
And are no longer are anodized.
Old 07-18-2011, 08:17 AM
That wheel looks very nice.
I cycle a fair bit and I've used Simple Green on my bikes, which have lots of aluminum on them, and I've never had a problem. As you say though, it's good to be aware of it.
If the item has a lot of cracks/crevices, those are the places to be concerned with. Rinse well and/or consider a final wash with dish soap and I'm sure you'll be fine. On the off chance a wheel gets corroded from Simple Green, it'll be a long, long time before it's anything more than a cosmetic concern.
2016 VW Golf R
2021 Kia Telluride
2020 BMW R1250RS
Old 07-18-2011, 08:42 AM
