jkeyzer's Avatar
MFI pump sprocket
Is the sprocket on the MFI pump reversable? Ie. if the teeth are worn down on the leading edge can the sprocket be flipped around and reinstalled? Crazy idea but a lot cheaper than a replacement part.
Jeff Keyzer
72 914 w/2056 built by Mark DeBernardi @ Original Customs
Megasquirt with MSII upgrade
Old 03-08-2002, 07:35 PM
zotman72's Avatar
Not sure if it is that simple. My engine is out right now so I will take a look.... The gear does wear as it is alloy but I think it only fits one way.
Bill
'72 911T-2.4S MFI Vintage Racer(heart out), '80 911SC Weissach,'95.5 S6 Avant Wunderwagen & 2005 997 C2S new ride.
Old 03-08-2002, 08:46 PM
Senior Member
Hello
Designed as a cup it will fit only one way. Rotating it will not make it useabler.
Grüsse
Old 03-11-2002, 09:03 AM
jkeyzer's Avatar
Thanks Roland.
Jeff Keyzer
Old 03-11-2002, 03:49 PM
Early_S_Man's Avatar
Porsche Crest
Jeff,
How about getting it hard-chrome plated to toughen/strengthen the wearing surface?
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 03-11-2002, 04:57 PM
jkeyzer's Avatar
Warren - interesting idea. It may be too late for this pulley, however, the damage has been done. The good news is the belt does not slip... yet.
You can see the worn spots in the teeth below.
Jeff Keyzer
Old 03-13-2002, 01:17 AM
Senior Member
Hello
Still thinking about it. Would there be any backsides ( Money no object ).
Noise ?
Wear on belt ?
Grüsse
Old 03-13-2002, 10:20 PM
