HenrikL's Avatar
Ground strap
It is three years since I removed the engine/gearbox and now I'm putting it all back together. I seem to have forgot how the grounding strap is attached. Is it attached to the stud in the picture below? How is the strap attached to the gearbox?
1977 911 2.7 Stock restoration in progress
Old 07-12-2011, 01:15 PM
Been There Done That
that stud and to the gearbox. I just took mine off recently.. sorry no pic at the moment
Old 07-12-2011, 01:30 PM
AutoBahned
RWebb's Avatar
any good spot on the trans. is fine
clean that area with a wire brush and solvent, then use water & detergent, rinse with water
next soak a paper towel with vinegar and stick it on there for a couple of days until it is all shiny while you hunt down a star washer for it
when everything is shiny, put some dielectric grease on & tighten it all down
inspect periodically to ensure it is all nice clean and shiny (a good electrical path)
same for the trans end
buy a new gnd strap and clean the ends before installing
Old 07-12-2011, 02:03 PM
83 911 Production Cab #10
JJ 911SC's Avatar
Holly Cow 3 years... It's been 7 months and I'm having a bad case of Cabin Fever
Here is pics of the strap on the transmission which I hope it will be in the car later this month.
Who Will Live... Will See
Old 07-12-2011, 02:19 PM
HenrikL's Avatar
Thanks for the info and pictures.
Three years is a long time, but both engine and gearbox have been rebuilt and I needed some time to get the funds to pay for that.
Old 07-12-2011, 10:32 PM
AutoBahned
RWebb's Avatar
hose that tranny down with Gibbs or something
Old 07-13-2011, 11:01 AM
JJ 911SC's Avatar
Old 07-13-2011, 01:08 PM
AutoBahned
RWebb's Avatar
it's cleaned but is the metal also protected from corrosion?
Old 07-13-2011, 01:17 PM
