Back to the ESS
Looking good there, Tex. Looks to me that hand forming the metal for the left over is very doable.
Kenik - 1969 911S - 1966 911 |
Dude!.....I have to give you the thumbs up for diving in. Just pace yourself, and don't burn out. Remember to spend some time with the woman....They kinda get funny when the car is more fun to play with!
air+fuel+spark
Thanks guys,
Kenik that sheet metal IS doable but I would rather not futz with it. It has way too much curvature for me to take on at this juncture. I can feel the clock ticking. I certainely could fab something up that is structural with out the fillets and radii but I want to avoid the Mad Max aesthetic if I can. Kelly, I HAVE been pacing myself Under normal circumstances my M.O. would be to just work all day all night until the job is done but my day job gets in the way. I also have a fantastic woman who is very supportive of my projects so when we need to spend quality time she gets priority. Besides, I have to build up some points because I know as we approach my spring deadline for a working car, there are going to be some late nights =)
bryan 1969 911T , '04 S2000, '96 900SS, 4x4 urban assault vehicle |
Restoration design seems to have what you need, though it's a bit pricey, maybe looking for a donor is a better idea, especially if you have to mod the part, which I don't know.
Gas tank lateral support, right 1965-89: Restoration Design Gas tank lateral support, left 1965-73: Restoration Design |
air+fuel+spark
Ubi bene ibi patria
Subscribed!
Good Luck Bryan - this project will be very interesting for all of us with the early cars. Cheers JB
Donec eris felix, multos numerabis amicos Ignorance is preferable to error, and he is less remote from the truth who believes nothing than he who believes what is wrong. -- Thomas Jefferson |
air+fuel+spark
![]() JB- Soon I hope to start actually adding the personal touches and getting the cars personality to come out and then this will all be a little more entertaining. For now we are in rehabilitation mode =)
bryan 1969 911T , '04 S2000, '96 900SS, 4x4 urban assault vehicle Last edited by combatic; 08-09-2011 at 12:26 PM.. |
Bryan,
Looks great! I can't tell you how happy I am to see someone bring life back into that car. Todd |
air+fuel+spark
Todd! So far behind on emails and chores etc. (the car has me pretty busy) I have been meaning to email you a link. I am stalled for a bit until I can get the rest of the sheet metal for the front to repair the rest of the rusted parts and then I can stitch up the front and start worrying about the motor =) Good to hear from you! Hope all is well.
deRegistered User
is all the rust from the Seattle area? or did this car come from back East?
I like the rgruppe sticker placement BTW |
air+fuel+spark
I am very suprised that the rest of the undercarriage and the window seals etc are still intact.Having fun so far! Thanks for the comments.
![]() OR ![]() Any use for these? Jeff |
air+fuel+spark
Jeff, apologies for the slow response, somehow I missed your post Jeff. How is the drivers side sheet metal? If it is at all decent I will take it. I will shoot you a PM as well.
Drivers side better than passanger. I will call you and see if we can meet this weekend.
jcl |
air+fuel+spark
Sounds good Jeff. I am tacking the car back together all this week and this weekend.
air+fuel+spark
Day 62 || Welding in the passenger side
7Sep11 Wow! A month has gone by! I have been finding time here and there to work on the car but I finally feel like I am getting some traction! I started out trying to Tig but I am not good enough with it and made a mess trying to get the main pan in. Too much heat build up and lots of blow through or adding too much and then having to grind it out to start over. I finally switched to Mig and sticking the metal together is much more relaxing Here is some of the progress so far.Pan roughly welded in and test fitting supports Battery box removal for weight reduction and really to make space for future TBD fender mount cooling...assuming I end up running some fantastic motor that is yet to be defined. Donor part for the passenger side sheet metal brought back from the Walker Swap meet! Thanks Chris patch piece cut from donor and being fit in place Re-purposing battery box sheet metal. I will be using the outside battery wall to fill in the hole where the battery boxes used to be. This will be convenient b/c they have a gusset built in for torsional strength and I can reuse the fender mounts. Finally welding in patch pieces! Mig is so much easier to tack everything together! The welds that look cold set in the image were where I was filling holes using a 'spoon' as a backer and welding from the inside. These will be ground flush. Pan with added welds and then etch primer applied. I taped off the areas where welds will be placed and this area will be painted with POL copper rich weld through primer. Seam seal applied.
air+fuel+spark
New passenger side longitudinal ground clean. The factory coating is not very durable so this part was stripped and I will etch prime and use copper rich primer at weld joints. Eventually this part will be protected on the outside with epoxy primer and the interiour will get 'cavity wax'. Waxoyl seems to be what is available and has been used for years by the Rover and Triumph/Brit car enthusiasts.
Longitudinal support finally welded in! Longitudinal 'stitch welded around the perimeter of the part for added rigidity (and as added insurance beyond the plug welds around the perimeter...remember I am not a professional welder and paranoid about my own ability at this point . Now I am ready to dress the welds a bit and then move on and weld in the A Arm support plate (sitting on the pan to the left)
bryan 1969 911T , '04 S2000, '96 900SS, 4x4 urban assault vehicle Last edited by combatic; 09-07-2011 at 11:49 PM.. |
Wow, that looks like a great job, Bryan!
James 1969 911E Slate Grey 1981 911SC Wine Red 1997 911C4S Ocean Blue |
"farking Porsche hero"
Nice work! You're going to be done in no time!
Rich '66 911 #303872 |
