There is no substitute
Question Car doesn't start..Any mobile mechanic in NY/long island area?
Hi,
My 83 targa all of a sudden has trouble starting and once it does..does not hold idle..have to hold the throttle down or it will die. .once the car warms up, it gets better.
Not sure what It is..
Recently I had a similar problem, and my mechanic fixed something with the airbox.
But this time..I drove it to him, and he said he doesent know..
It would be great if i can find a mobile mechanic that knows about these cars.
I also want to change the belts on my 993.
Anyone with any info..Thank you.
-Dave
The Hacker
96 C4S
97 C2 (Gone, but not forgotten
Old 07-15-2011, 03:18 AM
just me
paulgtr's Avatar
Send a message via Yahoo to paulgtr
you tried rudtner's already?
http://www.rudtnersracing.com/aboutus.php
1975 911s, 3.2l and 915 transmission front oil cooler RUF replica bumper ducktail and SC rear flares SW chip ssi's m&k 2 in 1 out sc front calipers PF 97 pads fuchs 16 x 7 and 8 225/ 245 toyo ra-1s 22/29 torsion bars 25mm Charlie Bars Neatrix bushings lowered and corner balanced DAS bolt in roll bar kirkey seat 5 point harnesses.
http://www.hairydoggrrrage.com/
Old 07-15-2011, 04:10 AM
Vin-barrett's Avatar
-Dave
probably this again, sounds like a massive airleak
take the airfilter out and see if the popoff valve is dislodged
-Vinny
1983 911SC
Old 07-15-2011, 09:07 AM
Thats what he repaired..the pop off valve. He glued it in place. What can the culprit be.
I know its related with the airbox.
The Hacker
96 C4S
Old 07-15-2011, 05:54 PM
