-   -   I don't understand cat by-pass pipes (http://forums.pelicanparts.com/porsche-911-technical-forum/619347-i-dont-understand-cat-pass-pipes.html)
nkotselas 07-14-2011 04:29 PM
Hello everyone,
I was just about to place an order for a bypass pipe thinking it would give me a somewhat significant power boost. I decided to do a search and found that most people say it will barely produce any more power and change the sound slightly. This confuses me.
I have a euro spec 3.2 engine, should put out 231 hp, but a cat was installed to pass my CA smog test :( so I thought that going to a by-pass would bring me up to 231 again, as I thought I was at about 217 with the cat. Will this be the case and was I just reading about US spec cars? Or did all euro cars have the euro pre muffler?
The exhaust has been something I haven't been able to understand quite yet :rolleyes:
Thanks for any help in advance SmileWavy
DRACO A5OG 07-14-2011 04:40 PM
You need to put in on a Dynometer to really see if there is HP difference.
But your butt dyno will tell you, your current low end torque may be lost to give way to the higher end torque at the wheels.
Sound is definitely more throaty and you may experience back fires/gurgles on decel.
My experiences,
Jim
rnln 07-14-2011 04:48 PM
Not sure how much you will gain without dyno comparison, but it's definitely a lot lighter. Not producing heat at the area like the cat.
If you are interested in a used one, I have it available.
911pcars 07-14-2011 05:13 PM
I believe euro-spec 3.2 engines have higher compression, around +10:1. That's the main difference in torque/HP.
Thus, it's not just the addition or deletion of a converter.
Sherwood
theclaw 07-14-2011 05:27 PM
Removed the stock cat and installed a sweet looking stainless bypass. (Yeah, could of punched out it out but then I'd just have a corroded hollow piece of steel that looked like crap.) Removed the O2 sensor. Steve W remapped my chip and the butt dyno says, BAM! Nice job. Feels like a new car. Pulls much better.
Flat6pac 07-14-2011 05:28 PM
Most of the ROW are 9.5 not the 10.3 as believed because you cant get gas for 10.3 all around the world.
Bruce
Swoboda 07-14-2011 05:31 PM
Isn't there also a basic difference between a cat bypass and a pre-muffler?
I thought a cat bypass was essentially just a straight pipe while a pre-muffler included some baffling--changing the flow and sound profile.
Peter Zimmermann 07-14-2011 05:34 PM
There are cats, and then there are cats. Is your cat a factory unit designed for the car, or some after market piece? If your engine is a true RoW 930/20 unit, it did have 231 DIN hp (170kW) at one point. If your engine was converted to M 298 specs, it will have only 204 DIN hp (150kW). If it was converted by slick willy's conversion shop, using a modified ECU and a junk cat, it might only make 180-190 DIN hp (I've driven some converted 231 hp cars that were complete dogs!).
A test pipe might help, but it might do little more than making the car noisier. It all depends what else was done during EPA certification, you might not even have the ECU that was with the engine originally. A Euro pre-muffler is your best bet regarding the exhaust, but more info is needed regarding the ECU. I'll let the electronics gurus work on that with you.
Maybe I'm missing something here, but you also don't want to upset the car enough to fail future bi-annual tests.
DRACO A5OG 07-14-2011 05:34 PM
Baffles? interesting I would like to know?
nkotselas 07-14-2011 05:44 PM
From what I know the engine should be almost completely stock. It is a 930/20 and I figured it would not have been changed at all especially since it only ha 23,000 original miles when it came to me. Would the PO have had to change the compression ratio or anything like that?
Also I have a SW chip programmed for the euro spec version. If I do upgrade the exhaust, how much will the chip hold back until I can have him remap it?
DRACO A5OG 07-14-2011 05:46 PM
'78 chip? Is your car a 3.2 with a DME?
nkotselas 07-14-2011 05:57 PM
Sorry, the car is a 78 but the engine is 84 carrera 3.2 euro spec
DRACO A5OG 07-14-2011 06:00 PM
Oh I see, then should be possible was the oil tank also updated to a 3.2 oil tank?
cbe060 07-14-2011 06:01 PM
m 499
my 84 euro is the german version [m499] 10.3 comp which calls for ron 98 unleaded..i have the euro premuffler, no 0,2,a b&b 1in 2out, this is my second 84 911 euro . when retured to thier german configuration they become like a race car as it says on SW,s website. ive owned 87 and 89 3.2s and a 97 993 and for raw power you can beat a euro 3.2 for imho http://forums.pelicanparts.com/uploa...1310691593.jpg
DRACO A5OG 07-14-2011 06:04 PM
Damn to be a Euro, Hmmmm, but to obtain pure 98 octain unmolested by eth is impossible here in People Republic of Kalifornia
nkotselas 07-14-2011 09:47 PM
I think the tank has actually been updated
What I really want to know is what that "german configuration" is
IROC 07-15-2011 04:08 AM
He actually said ron 98. Our 93 (mon+ron/2) works just fine with 10.3:1.
db_cooper 07-15-2011 07:10 AM
With a cat bypass you will not be cooking the left exhaust valve cover and tire when parked..it gets hot under there!
attamz 07-15-2011 07:14 AM
I just like to pollute the environment.....kidding. I def. noticed a difference w/ the bypass, muffler and chip. The bypass gives the car more of a hollow muscle sound.
PatrickB 07-15-2011 08:39 AM
Best bang for the buck, without doing major changes, is cat-bypass with a SW Chip. better all around performance, and MPG's too! The OEM muffler actually flows fairly well, but a significant improvement can be had with the bypass!
