running hot?
My 73 911 T is at 6100 feet in western Colorado. The temps around here lately have been in the low to mid 90's. On fairly flat terrain, the engine temp is about 210 or a little less. I have an elevation change from 4900' to 6100' in the eleven mile run from the town I frequently visit to my home. Today, the engine temp went up to close to 230. Is this an unusually high temp? What is normal? My mechanic says probably no big deal, but what is your experience?
Thanks, gary
Old 07-16-2011, 05:31 PM
76 Targa's Avatar
230 is about the upper limit for what I'd want my engine oil temperature to be. I live in the desert, so I added a front fender mounted carrera cooler with a fan. Even with my air conditioning running on a 105 degree day, my oil temp stays at around 125.
76 911S Targa Widebody, 61 VW Bus, 2012 Fiat 500S
Old 07-16-2011, 07:42 PM
Midwest R Gruppe
t6dpilot's Avatar
I recently asked the very knowledgeable person who maintains my cars this very question. He stated that 225 is probably the upper limit for safe oil temperature - anything above that is getting pretty hot. I would say that an occasional visit into the 230 territory is probably OK, but I would avoid regular sustained runs at that temp or higher.
Scott
69E Coupe 2.2S LtWt
73.5T Coupe
Old 07-18-2011, 08:35 AM
This is not possible!!!!!
76 Targa,
125°F oil temperature is COLD and not even close to the operation temperature designed for air cooled 911 cars. Are you sure you got your number correct? Auxiliary thermostat operates around 186°F (+/-) a few degree. The moment you start your motor it will warm-up slowly to operating temperature. A cold engine is under 113°F when a TTS (thermotime switch) is needed. Keep us posted.
Tony
Old 07-18-2011, 09:47 AM
