Lowering Seats
Picked up an 84 911 that has Sparco Evo seats mounted on factory sliders. Problem is the seat is not low enough for when wearing a helmet. The lowest holes on the side mounts were open, so I tried to lower the seat into that, but the bottom of the seat hits the floor and makes the bolt about 1/4 inch off. I did try raising the fronts up a bit to see if the angle would help, but it didn't. What are my options? Remove the factory slider and mount directly to the floor? Here's a couple pictures of the setup. Thanks for the help!
84 911 - 88 944 Turbo S - Sold
996 Turbo
996 Cab
Old 07-18-2011, 06:27 AM
porsher
aston@ultrasw.c's Avatar
I removed the sliders and attached the sparco brkts directly to the floor mounting points.
I did have to relieve the underside of the seat in two locations to clear the mounting bolts.
Your seat looks a bit narrow is it the Evo? My Evo II was the perfect width but the Evo was too narrow. It required that I fabricate an adapter made from flat 1/8" steel plate with two bolt patterns.
I might have some pics somewhere
86 911 Race Car, with a few 993 bits in the boiler room
79 928 Race Car
88 928 Becoming a Race Car
Old 07-18-2011, 07:33 AM
porsher
For pics see this thread
Harness mounting
79 928 Race Car
Old 07-18-2011, 07:37 AM
Yes, mine are the regular Evo's, they are a bit tight for me, but came in the car when I bought it.
996 Turbo
996 Cab
Old 07-18-2011, 10:15 AM
