-   -   open reservoir tensioner (http://forums.pelicanparts.com/porsche-911-technical-forum/619630-open-reservoir-tensioner.html)
carrooth 07-16-2011 10:36 AM
http://forums.pelicanparts.com/uploa...1310840589.jpg
I have my muffler and heat exchangers off (no stuck or broken studs :D ) and just completed a valve adjustment (backside method)
I figured while the muffler was off I would rebuild my tensioners and put safety collars on. The engine is completely stock and I have the open reservoir tensioners.
I was surprised by the tensioners when I removed the covers because I expected to see the "new" style tensioner with the sealed reservoir and a bleed screw on the side.
The "new" style tensioners have some rubber o-rings inside while what I have, as far as I can tell from the picture, has no rubber pieces inside.
If I am correct and there are no rubber pieces inside is there any reason to open these old tensioners for a rebuild?
What is it that fails with the tensioners normally? I am assuming o-ring failure releasing the fluid pressure. Do the springs fail?
Thanks for your input
carrooth 07-20-2011 08:23 AM
Replying to my own post...
I went ahead and used two parts from the tensioner rebuild kit and replaced part #5 and #7. These were plastic and I'm discovering 45 year old plastic is brittle.
Now for my next question. Has anyone attempted to install a tensioner guard on the open reservoir tensioner? To me it appears it wont fit...small cup large guard.
Anyone?
Thanks, Jay
john walker's workshop 07-20-2011 08:45 AM
if you still have the ancient rubber ramps in there, be sure to replace them with the plastic ones. the ends break off and go through the sprockets. not a good thing. probably ought to get rid of the ancient tensioners too.
carrooth 07-23-2011 02:30 PM
Thanks John,
I've been looking into the ramp issue and discovered something interesting. I have no black or brown ramps only "plastic faced aluminum" ramps.
I seem to be coming up with more questions than answers. Are plastic faced aluminum ramps better than plastic ramps? Are the plastic ramps even interchangeable?
