-   -   alternator light just came on? (http://forums.pelicanparts.com/porsche-911-technical-forum/619645-alternator-light-just-came.html)
plumb4u2 07-16-2011 12:11 PM
Ok guys I have searched but want your opinion before I proceed
Yesterday I came home from work and pulled in the garage and noticed that the battery light was lite (first time this has happened in my year of owning). I reved the engine and it went out then after bout 30 sec of idle came back on.
I searched some threads and did some checks
my belt is tight and no slipping (I replaced belt this winter as maintenence)
today I checked voltage at battery with car at idle 12.4v...had wife rev to 3k and got 13.4v
So from these checks I believe that alternator needs to be replaced?
Battery was made 09/09
Bob Kontak 07-16-2011 01:57 PM
Does the voltage bounce around a little when measured? If so probably the v regulator.
86 911 Targa 07-16-2011 02:01 PM
3.2 Alternators.
You should have 14.5V @ 3K RPM's.
Things are pointing to the VR, easy to replace.
Get your system checked out.
Someone sent me this.
http://forums.pelicanparts.com/uploa...1310853647.jpg
plumb4u2 07-16-2011 02:19 PM
i did not notice reading bouncing around but i will recheck
if it is the VR would it make sense for me to replace just that or the whole alt.
i believe i saw our host sells vr for 65.00 for that much wouldnt it be better to replace whole unit
i have no history on this alternator
wwest 07-16-2011 05:00 PM
Miles...??
High miles....
Alternator slip ring brushes have worn out.
Driver_X 07-17-2011 04:43 AM
If it's an un-modified '84. Then the VR will be integral to the alt. Change out the whole unit....
plumb4u2 07-17-2011 06:17 AM
yes un-modified '84 only 91k miles
Autozone has a duralast alternator, has any one used this as replacement
165.00 vs almost 300.00 from our host for a bosch
I know the VR is integral to the alt but it can be replaced just dont think its worth the gamble
Joe Bob 07-17-2011 08:59 AM
I prefer to have a local shop rebuild mine....
plumb4u2 07-18-2011 02:41 PM
Hey Joe Bob, or anyone else, what type of shop will rebuild Alt.... meaning what should I look up in the phone book
Joe Bob 07-18-2011 02:42 PM
altenators, starters, automotive/electrical, or ask the local wrench for a referal. Good wrenches don't buy Manny, Moe and Jack crap.
boyt911sc 07-18-2011 03:12 PM
Local shop.......
Whenever I have problem with either my starters and alternators, I simply pull them out and bring the unit to my local electrical shop. It takes a few minutes for these guys to determine the condition of your unit/s unless you are familiar or have the apparatus to make the tests. My starter is 15 years old after the rebuild and still going strong.
Tony
