Moke81's Avatar
gas fumes on fillup
Where are the fumes emanating from the neck, at the sending unit or somewhere else?
Barclay
______________
1981SC coupe
Old 07-19-2011, 06:11 PM
RETIRED
Joe Bob's Avatar
Charcoal canister or cap gasket.....
2012 ML350 3.0 Turbo Diesel
Old 07-19-2011, 06:13 PM
Fleabit peanut monkey
Bob Kontak's Avatar
Gas cap seal like Joe Bob says.
Your post is a bit sparse. Assuming inside the cabin you smell fumes?
Old 07-19-2011, 06:17 PM
Moke81's Avatar
so the canister itself is leaking?
cap passed CA. smog in June I don't think its that.
Old 07-19-2011, 06:22 PM
Moke81's Avatar
sorry, yes inside the car.
Old 07-19-2011, 06:24 PM
Barclay
______________
1981SC coupe
If only upon fill up, my guess is leakage at the fuel filler hose. That's the only time liquid fuel is at that level. You may not even see the leak since it only takes a small amount of fuel to vaporize and waft into the cabin.
At levels below "full", you should be able to see liquid fuel at the source of the leak.
Overfilling could saturate the canister with fuel and also introduce a fuel odor in the cabin.
Sherwood
Old 07-19-2011, 09:34 PM
Moke81's Avatar
thanks for the responses, I am going to research it further.
Old 07-20-2011, 11:05 PM
gas fumes
are the fumes inside or just more noticeable in garage? I have had lots of fumes that if I fill up the gas tank too high. but none inside.
'72 1.7 under renovation
Old 07-21-2011, 03:21 AM
1988 Carrera
shadowjack1's Avatar
Had the same problem on my 88, turns out the expansion tank line was broken. My expansion tank in the left front fender above the water tank. Don't know if your 81 has the same set up.
Old 07-21-2011, 03:40 AM
Moke81's Avatar
only after fillup
Old 07-21-2011, 08:59 AM
balleta's Avatar
Check the seam around the fuel tank. They are prone to leak if rusted but can be repaired.
911 C2 Turbo Look
Harley Fat Boy
Jeep TJ Sporttrac Adrenalin
911 SC(sold)Sporttrac(sold)
Old 07-21-2011, 10:39 AM
