vacumm hoses
Its me again, The guy thats son in an effort to help me pulled all my hoses lose from the engine.I have connected the hoses for the cruise control but have one more hose to find where it goes. Its the large hose that comes out of the carbon filter can. It has two hoses running to it . I found where the small hose goes but cant find where the large hose hose goes on the engine. Any help would be received with gladness
Also my 1980 911 SC has stainless exhaust and there is no place on them to screw the O2 senser into. Does somebodu make a stainless buge to screw it into . It has to be stainless to be welded to the exhaust.Any ideas |
I'm not sure if its the same hose as you are referring to but the bigger hose on my carbon cannister goes to the left side of my airbox
1975 Aubergine 911S - Barney "When that doesn't work, and it doesn't quite often, it's as though your face has been amputated." - Jeremy Clarkson |
I think so too - can't help with the O2 bung question, although if you do a search I thought I saw someone with a similar question.
See if this figure from a later model helps w/ the vac lines.
Dan '87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip Venetian Blue |
Thnks guys, you are the greatest
