CO too high (year 1996, 993)
Hi,
My 1996 993 carrera (Euro engine) failed its annual emissions test due to high CO readings. The readings were as follows: IDLE: - Lambda 1.030 - CO 0.679% (fail, limit 0.50) - CO2 13.77% - HC 136 - O2 1.21% AT 3000rpm - Lambda 1.014 - CO 0.779% (fail, limit 0.30) - CO2 13.99% - HC 52 - O2 0.84% After running at 5000rpm for 5s, HC reduces to zero, and stays there even on idle as catalysts are hot. By doing the same, I managed to get the CO for a while to 0.369, which fails the test only by a whisker. Engine is running smooth and strong. Any suggestions on how to pass the test? Would removing the breather hose during the test help? I got only few days to sort the thing out before the valid test expires, so any quick and temporary fixes on how to pass the test appreciated.
1996 993 Carrera 1998 996 Carrera 2000 986 Boxster S |
RETIRED
HC goes up, CO goes down. Get to an indy shop and put it on an analyzer. Adjust from there.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
By the lambda you are where you should be (+/- 2 or 3%). I would suspect catalysts are not working well. Especially when the statement is made about warming the cat up to reduce hc. Could this be a high mileage car with worn valve guides?
Thanks for the advise. It was spot on .
You can pay now, or pay later...
If it flows, it goes. If its smooth, it moves. Any questions? 96 993 C2 (Current) 87 911 Factory Turbo-Look Cab (Sold) 85 911 Factory Turbo-Look Targa (Gone) |
