-   -   Shifting problems (http://forums.pelicanparts.com/porsche-911-technical-forum/620111-shifting-problems.html)
JTH 36 07-19-2011 08:14 AM
Shifting problems
Good Morning All,
I was driving home on Sunday and noticed that the Carrera did not want to shift into 5th gear. It also does not want to go into Reverse. I have never had this issue before and it just come up out of the blue. Do you think it could be a shifter coupler issue? It has always shifted great up to this point.
Jeff
CCM911 07-19-2011 08:55 AM
I sure would take a look at the coupler first. Since 5th and Reverse are on the same plane, I would bet on adjustment issues.
911pcars 07-19-2011 12:01 PM
I would bet on wear issues. Check coupler, shift rod and shift lever bushings.
Sherwood
