quick question on rear shock replacement
Hi guys,
As many of you may recall, I'm in the midst of a complete suspension rebuild on my 912E.
My current problem is that I cannot break loose the bottom bolt holding the OE shock absorber into the banana arm.
I've used plenty of time+penetrating oil. I even heated the arm with a little propane. No luck. I've put a piece of pipe on the wrench for leverage, no good.
I'm more than a little worried that I'm going to snap the bolt head off. This is the original shock, so what kind of torque was used to seat it? As far as I can tell, the rear suspension has never been taken apart before. I'm baffled.
I'm sorta stuck here, and any advice would be appreciated.
Thanks,
Old 03-10-2002, 04:32 PM
they can be difficult, but it's a big bolt, so it's not going to break. up on a rack would certainly be easier to get a good pull on it, as opposed to being on the ground.
206 637 4071
Old 03-10-2002, 04:44 PM
thanks John, that was my primary worry. Since it's on jackstands, it's tough to get a good pull on it. But, I've nearly hung from the pipe, and at my 200lbs., I was mystified that it didn't budge.
Old 03-10-2002, 04:47 PM
Early_S_Man's Avatar
Porsche Crest
Dave ... 26 years + aluminum + steel + some cadmium plating left = a major corrosion problem with over 1" engagement in the aluminum bore ...
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 03-10-2002, 04:53 PM
Warren, I knew that's what you'd say. Is this just a matter of putting enough pressure on it? I mean I guess I can figure out some way to wrestle it out if I have no worries about that bolt head ripping away.
Old 03-10-2002, 05:07 PM
an abrupt snap with the tool works better than an even pull. i've never broken a bolt or stripped the threads, YET.
206 637 4071
Old 03-10-2002, 05:15 PM
okay, thanks guys!
Old 03-10-2002, 05:17 PM
pwd72s's Avatar
I remember an earlier post...made by the son of a commercial fisherman. This fisherman swore tabasco sauce loosened frozen/rusted nuts better than anything. Oil of Capsium...have any of us "inland" tried it yet? not me... Whatever. I would think something designed to be a nut loosener, applied on the upper end, then let it soak, wouldn't hurt...
Old 03-10-2002, 06:51 PM
autobonrun's Avatar
After soaking mine with penetrant for several days, I was able to get mine to move by using a floor jack to lift the ratchet. You should be careful it does not slip off but this worked on both sides. Make sure you have a good ratchet and keep your head back for safety measure. Go slowly and gradually apply pressure and it will break free.
Old 03-11-2002, 09:35 AM
thanks for the additional tips guys.
Old 03-11-2002, 10:21 AM
