Aftermarket AC? in SC with no air now?
Every time it gets hot outside, I think about installing AC in my SC. I've seen old hotrods with AC, so could i use one of those set-ups? Is this a DIY job? Or would it be too messy? Or just buy a beater with AC to drive for the hot months?
My SC looks like it has never had factory AC, I don't see any extra parts installed, and the smuggler box is empty. Anyone gone down this path before?
Scot 78 911SC coupe, sold,, 2019 Macan S "my friends all drive Porsches, I must make amends.." |
1983 911SC Chiffon Weiss
A kit for a hot rod won't work. They are designed for a typical Ford or Chevy V8 set up with the condensor installed in front of the radiator. And quite often the engines are in fact newer and are already set up to accept the brackets needed to mount the compressor.
If your lucky a PO simply removed the AC at some point and you could just reinstall a system with some upgrades (tons of options here). Pull the passenger side floorboard and see if there is a hole that goes to the smugglers box. If there is you're in luck it means your 911 left the factor with AC. If your 911 never had AC it can still be installed, there are few posts here from folks who've done it, but its not so simple. The most difficult part will be cutting the sheet metal under the passenger floor board into the smugglers box for mounting the evaporator and also under the dash to route air from the evaporator back into the cabin. Most of the rest would be pretty straightforward. You could source the brackets, pulley, etc. to install the compressor and decklid condensor and probably use a fender condenser in place of the one in the front. Then of course you have to install the wiring/controls.
1986 Carrera Coupe 1999 Chevy Tahoe 1987 Chevy Blazer 1955 Chevy Apache 3100 Pickup "A little knowledge is a dangerous thing" |
Yeah, my 79 911 has AC, then it looks like a few custome made vents to blow a bit more air. I'd do it in a heart beat if I were you. the bracket that is on the passenger side in teh engne bay will interfere a bit with yourt heater hose, so you may need a reducer to wind it back down in there. And you may want to just double check that your crank shaft already has the 2nd outer pulley to run the belt. In my smugglers box, there appears to be a ac blower or something and then just under the dash is a couple items. The evaporator sits under the deck lid, and gotta adjust the coil on the shroud so it closes ok. Are you already running an air pump?
1979 911 SC 1974 OEM 911 Exhaust and Muffler - Modified to a 2-out Fiberglas Goodies, 17" C4 Cup Wheels |
score! I already took off the air pump, so I have a free empty pulley! good idea.
and I really like the porsche and jaguar kit company. thanks for the link. that looks way better than trying to piece it all together from the used classifieds. next summer, I'll be all in-style cool! thanks,
I would give Rock at retroair a call, he is an easy guy to deal with.
Jim Holmes
Another option, use an universal evaporator in the trunk with outflow hoses routed to center and under dash vents. The air intakes go to the smuglers box to get air recirculated. The evaporator is covered by the trunk carpet. Have seen a few systems like that here and they work well. You can feel the increased airflow at the vents over the stock setup. And is A LOT cheaper than upgraded evaporators.
![]() 911 C2 Turbo Look ![]() Harley Fat Boy ![]() Jeep TJ Sporttrac Adrenalin![]() 911 SC(sold) Sporttrac(sold)
Be sure to check out Griffeth A/C. Top quality, but pricey. One usually gets what one pays for.
81 911 SC 04 Lexus SC430 04 Lexus LX470 06 Toyota Landcruiser 91 Ford F250 07 Camry Hybrid 11 Honda Accord LOTs of car insurance bills!
question. Using the alternator pulley to power the AC compressor? OI wuld not think you would want to do that. When the AC comes on and puts a load on that pulley could that cause an issue at all? You don't want to burn up alternators.
Just curious, what do you all think?
for sure. these guys are the only way to go if you want a/c that's actually cold, and parts that are designed specifically to fit the unusual arrangement of the 911. it's definitely do-able to get ice cold a/c in a 911, but this undertaking isn't for those with a thin wallet if you know what i mean.
SOLD: '87 Carrera |
