green fuel line
Hello,
THere are two green fuel lines that run from under the transmission to the engine compartment. To remove on of them, do I have to remove the transmission mount plate? The fuel line connection seems to be unaccessible and tucked up above that plate. Thanks Scott
'80 911 sc '96 Range Rover |
On an SC, the fuel lines are single pieces from the tank or pump all the way back to the engine. That aside, to get to the openings in the rear firewall at the tunnel, you can remove the trans mount by placing a jack under the transmission and then removing the 2 large mounting bolts followed by the four small nuts securing the mount to the gearbox. Oh, the sway bar will need to come off as well.
ok, thanks, thats what i was thinking. But on my car i believe i see a connection right above the tranny mount and sway bar.
Thanks scott
the fuel lines have a flared fitting for both feed and return lines right above the gearbox mount immediately where the floorboard terminates rearward. on both cars above, the fuel lines from that point to the engine bay are discreet lines with flare fittings at both ends. Hard lines on the 83, flexible rubber lines on the 78
2002 Porsche 911 turbo 2007 Porsche Cayman S track car 1987 Porsche 924 Carrera GT tribute 2015 BMW X5 |
Are the fuel feed and return line the same pressure (not high pressure like the injector lines)?
thanks scott
'80 911 sc '96 Range Rover Last edited by scott.k; 01-09-2011 at 04:51 PM.. |
I honestly don't know, but i'm highly doubtful the return line is a high pressure system. The feed line is, of course, high pressure
ok, thanks, i did not specify clearly but i was asking if the feed line is low pressure like the return line and you answered my question so thanks for the help
Fuel pressure lines.......
The return line does not experience the same fuel pressure as the delivery pressure on normal condition but could experience similar fuel pressure when total blockage occurs. This is very rare occurrence but for safety reason the return line should also be fuel injection type hose (high pressure rating). In the presence of return line blockage, the delivery and return lines could experience greater fuel pressure than the injection lines. The injector lines pressure is controlled by the system pressure (65 - 75 psi.) while the fuel line/s could get as much as 100 psi. or more pressure (FP capacity). HTH. Tony |
Hello,
I got two M14 x 1.5 female fittings a while ago but they are very low flow. I was wondering if anyone knows where I can buy two fuel fittings: 1) female M14 x 1.5 that fits 3/8" ID hose that is this type of fitting: http://mothersperformance.com/images/F24637582.jpg 2)male M14 x 1.5 that fits a 3/8" hose that is this type of fitting: http://static.summitracing.com/global/images/prod/large/rus-639210_cp.jpg thanks scott
Scott:
Try batinc.net Cole
Cole - 80 930 "The Old Sled" Mods: TurboKraft Custom IC, 934 Headers, GSX 61, Zork, Port Work, SC Cams, Air Mod Fuel Dist Relocated, Water Meth Injection, BL WUR, MSD 6530, Greddy EBC, Synapse Bov, Short 2nd & 3rd with 8:37 R&P, Wevo Shifter, Coupling, and Mounts, MTX-L SSI-4, Big Brakes, Rebel Coilovers, Bilstein Sports. |
Cole, thanks a lot, they do have the female fitting that I am looking for, now ive just gotta find the male one
-scott
Scott
I presume that this is for the return line?
Gary Kozun 83 911SC Cabriolet |
yes, the female fitting is for the return line and the male will attach to the end of the feed line
thanks scott
