Engineer of profanity
924CarreraGTP's Avatar
Early 911 muffler removal?
Hello again! Last night I tried to pull the muffler out of the back of my 1970 911 to do the motor mounts and install timing chain tensioner stops. Some numb nutts put the muffler strap bolts on the back side of the muffler behind the bumper. I got the heat exchanger bolts out no sweat, and it looks like two bolts on the engine mount will drop the muffler. Is this true or what?
Surprisingly, I already got the engine mounts in the car with the muffler still installed. Any help will be appreciated. I'm a 928 guru, 911s are not my forte.
1970 Porsche 911T Black
1990 Porsche 944 S2 Red on cashmere
1984 Porsche 928S Euro ROW GP white on black
Old 07-22-2011, 01:45 PM
I would rather be driving
jpnovak's Avatar
Pop the plastic plugs out of the bumperettes and pull them off. They are held on with 2 hex bolts on the top and bottom. then pull the rear license panel. Don't forget the sheet metal screws in the lower mating edge to the side bumpers.
Then, You should have easy access to the muffler straps.
The engine mount will not come out easily as you have to slide it backwards pretty far to clear its mounting studs. I doubt you have room with the muffler in place.
Old 07-22-2011, 02:06 PM
Cool, nice idea. I noticed the bumperette allen bolts and I knew the rear panel comes off, I just wasn't sure how to do it. The license panel is bent too so that will give me a chance to straighten it up while I have it off. The muffler is very close to the license panel. So hopefully what you're explaining doesn't include getting behind the license panel. I'll check it out later tonight.
Old 07-22-2011, 02:28 PM
lateapex911's Avatar
No, it's all very easy. Probably take you 10 minutes max to get the rear panel off.
Jake Gulick, Black Rock, CT.
'73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B]
Old 07-22-2011, 07:59 PM
