Send a message via Skype™ to Porboynz
1972 Fuel Pump wiring routing: Brain Fade
Its been 10 long years since I dropped the engine out and stripped the engine bay. I am ready to reconnect the red green wire in the engine bay to the fuel pump but can not remember the correct routing for the wire to the pump. I am fabricating a new wire with a ground lug and spade connection for the engine bay end and a bosch female plug for the pump end. Question is, does the wire follow the fuel line through the corner of the engine tin sealing rubber or does it route forward of the crossmember?
1972 911T Coupe with a '73E MFI engine and 'S' pistons
10 year resto mostly completed, in original Albert Blue.
***If only I didn't know now what I didn't know then***
Old 07-24-2011, 11:31 PM
lol porboynz
I'm in the same boat: I've forgotton most of what I've learnt after 10 years with a T.
Trust you're in early911nz, cheers Matt
'72 911 T/E Silver Targa
Old 07-25-2011, 12:54 AM
