-   -   Innovate lc-1 and auto timer install issues (http://forums.pelicanparts.com/porsche-911-technical-forum/621076-innovate-lc-1-auto-timer-install-issues.html)
Ramathorn 07-24-2011 06:23 PM
Well a few days ago i wanted to install my innovate lc-1 and my innovate auto timer but, with so much going on ive been pulled away from it multiple times and i cant seem to figure out my issue and was hoping someone that has install experience can help me troubleshoot my issue.
I just finished up my install of the two items to what i thought was to the exact specs of the directions but, when i turn the ignition on the small led never lights up and my gauge reads a solid 7.4. I know my gauge is reading because it has timer function and volts read and display on the gauge. One slight discrepency I had with the instructions what that it states to hook up my gauge to analog 2 the brown wire(I would think that analog 1 yellow wire) i dont know if that was a misprint or if it actually is suppose hooked up to analog 2.
Any help would be greatly appreciated as i want to get my car back on the road!
DUK 07-24-2011 07:07 PM
What gauge are you using? Analog two (brown wire) is the wide band output and is what is used for most gauges and ecm's.
Ramathorn 07-24-2011 07:14 PM
I'm using an innovate auto timer (reads volts, afr, and is a timer).
cmcfaul 07-24-2011 07:27 PM
The brown wire should have around 5 volts to it when on, engine off (reading non exhaust air). The yellow wire I believe connects to a light source to auto dim the gauge. Check the brown wire for voltage. Mine stopped working and I found the brown wire was not hot. Innovate sent me a new unit.
also, hook up a lap top and see if that reads correctly. That will tell you if it's a guage problem or other.
The fact that the LED is not working is not a good sign.
good luck
Chris
73 911 e
kerthunk 07-24-2011 08:37 PM
I had a dead LED in my kit. It seemed like the LC-1 wasn't working (since it wasn't flashing). I hooked my multimeter up and saw that the voltage was there. Went over to Radio Shack and bought a new 12v LED along with a small project enclosure. Put it all together and it has been working fine since.
I would try hooking up to logworks on a laptop and see if the LC-1 is functioning.
Ramathorn 07-24-2011 09:06 PM
Okay i took a break ate some food and went back out to try and trouble shoot some more and came back with the same end result of a non functioning lc-1 but, now im just more frustrated with the install. Im contemplating just scratching the whole thing removing it and starting again from a clean slate. Anyone have a write up on their install? What color wires and where they connected their lc-1 wires upto? Pics would be great.
Seriously time for a beer now!
Ramathorn 07-27-2011 01:18 PM
Well I woke up this morning ripped everything out and rewired it all. Working like a champ now i just need to build my gauge holder and hook up my vacume gauge and ill be set!
