cmcgee's Avatar
1986 911 Power windows and sunroof stopped working
The power windows and sunroof in my 1986 911 Carrera have all of a sudden stopped working. It appears to be electrical...possibly fuse or relay? Any suggestions on where to start looking for solution? Thanks! Chris
Chris McGee
2003 996 TT (X50 PCCB Aero)
1991 928 S4 (stock)
1986 911 Carrera (bad-ass)
2014 Cayenne Platinum (daily driver)
Old 07-25-2011, 05:13 AM
crustychief's Avatar
look at the rearmost fuse in the fuseblock in the trunk, if that is good then it is probably the relay, you can swap them around to verify. ( edit. There is a relay under the dash for your power windows, it is a 944 part number not listed in the 911 electrical parts on PP )
A nose heavy airplane flies poorly, a tail heavy plane flies once.
Old 07-25-2011, 08:31 AM
WHen working the switch, do you hear anything or see anything move? If you do, then most likely a Cable has pulled loose
Made History at Daytona and Still one Fast Old Man! 1982 Porsche 911 SC & 1982 BMW 320i
Old 07-25-2011, 09:06 AM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
fUSE
Chris,
I agree with crustychief.
The fuse is the obvious starting point,
as it controls both functions.
Here's a few pics.
Good luck,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 07-25-2011, 09:16 AM
cmcgee's Avatar
Gerry,
I checked the 1st fuse and it looks fine. I switched over another fuse to this location and still nothing. The Bentley manual shows for relays in the front trunk, I should have an empty hole in space 1, Relay 1 in space 2 not used, Relay 2 in space 3 for windows but I have an empty space in the relay board in this position? I have a total of 5 relays in place. Not sure what to check next. I'd appreciate your further help!
Chris
Chris McGee
1991 928 S4 (stock)
Old 07-25-2011, 11:46 AM
cmcgee's Avatar
Here's a photo of my front fuse/relay box.
Chris McGee
1991 928 S4 (stock)
Old 07-25-2011, 12:05 PM
Your relay is behind your fuel gauge, it is a big square one with 5 prongs on the bottom. it is a 944 part number and it is called a power window controller.
Old 07-25-2011, 12:25 PM
Pelican Parts - Product Information: 944-615-116-00-M100
Old 07-25-2011, 12:30 PM
cmcgee's Avatar
does this relay also control the power sunroof which is also not working?
Chris McGee
1991 928 S4 (stock)
Old 07-25-2011, 01:09 PM
Power window relay.
Here you go.
But, I don't think It's your PW relay.
Good luck,
Gerry
[img]
1986 911 Targa.
Only in L.A.:
Old 07-25-2011, 01:47 PM
Gerry,
Chris
Chris,
When you checked fuse #1, was there voltage on both sides?
Here's the relay panel for our '86.
I used slot #1 for our Front oil cooler fan.
The Bentley is wrong............again.
You may pm me.
Good luck,
Gerry
1986 911 Targa.
Only in L.A.:
Old 07-25-2011, 01:56 PM
cmcgee's Avatar
Gerry. I don't have a voltage meter so not sure how to check if voltage at both ends. What do you think it is before I begin tearing into my dashboard?
Chris McGee
1991 928 S4 (stock)
Old 07-25-2011, 02:26 PM
Here is a circuit.
You will need a meter, or a replacement window relay which would be a "guess".
The relay is best accessable behind the fuel gauge which pulls out towards the driver's seat.
Here is a circuit description.
This is the best I can do for you.
Best,
Gerry
1986 911 Targa.
Only in L.A.:
Old 07-25-2011, 02:53 PM
7-22-15
I have the same problem, which includes the power mirrors.
Can someone send me some photos on how to get the gauges out so I can access this electrical module? Perhaps there is a link here that will walk me through this problem.
Perhaps a contact clean will help as the problem comes and goes.
thanks
Old 07-22-2015, 06:46 PM
jdbunda's Avatar
I can't remember, but I think I was able to replace the window relay without pulling gauges, but I could be wrong about that. Relays often go intermittent before they fail completely, mine did. You might be able to pull off the cover and clean the internal contacts, I didn't bother, I just replaced.
If you need to remove them, the gauges are just pressure fit with a rubber gasket around the gauge behind the trim bezel. Just grab at the trim ring and pull toward you, you might have to wiggle it around a bit, they are a tight fit. Some are easier to get out than others, if you can get one out, you can reach through the hole and push the next one out from behind. If they are really tight, use a plastic trim tool to pry a bit to get it moving (being careful not to scratch the dash).
Sometimes a fuse looks and tests good, but is not making good contact in the fuse holder. A multimeter might show 12V at the fuse tip, but current is not getting through to the other side. Clean the fuse tips and the contact surfaces in the fuse holder, and put on some dielectric grease.
Several current threads in this forum about replacing the entire fuse panel with modern blade style fuses, this is definitely on my project list.
John
1972 911T 3.0L Coupe
1986 Carrera Targa
1989 BMW M3
2007 328iT
Old 07-23-2015, 09:11 AM
Sorry Newbie here. I realize this is a very old post
Power Window Woes
I feel as though I have read every post on Power Windows Issues
I am hoping that some kind soul will help me understand where the power comes from for fuse #1 in the luggage compartment.
When my Power windows dont work there is no power at this fuse posistion at all, even when touching the wire directly.
When my windows dont work the Red Wire with Blue Stripe has no voltage. Is this fuse position fed by the ignition switch ot the Power Window Control Relay 944-615-116-00.
PLEASE AND THANK YOU
Old 09-13-2017, 01:29 PM
