1. What chip for 84 911? 2.Big Reds..
I live in PHX and removed stock exhaust and installed a header system from Rennsport and put a Flowmaster 80 series on.
Reading from files past, I still cannot come up with a chip to buy (or NOT).
I understand timing and fuel are changed with a chip. Is this true? Can anyone recommend a good chip? Keeping in mind the summers are 100+. Any other inexpensive external mods?...
Of course, every two years I gotta go back to stock assembly for DEQ.
PS. I may be selling my brakes to a friend in a 71, has anyone put on the big reds a carrera?
Old 03-09-2002, 08:20 AM
Glasgow 911SC's Avatar
Kurt B (on this board) runs with a Weltmeister chip & along with his mods, claims great results!
Chris
1982 911 SC Hellblau Metalic
1997 Boxster 986 2.5l
Old 03-09-2002, 08:46 AM
Send a message via ICQ to Kurt B Send a message via Yahoo to Kurt B
i have a weltmeister. It'll ping with 91 octane which is all i can find. Be prepared to add octane booster to your gas you will need 93 octane minimum.
yes, it lives up to its boast of +20 HP at the higher rpms as witnessed in my other posts on 0-60 times and hp.
-kb-
Student of the obvious
LeeH's Avatar
Something to be aware of: Early '84 chips were solered in the board (not socketed).
Old 03-09-2002, 12:49 PM
makaio's Avatar
If you put Big Reds on, you will have to put 17" wheels on as well. They won't fit under 16" Fuchs.
Old 03-09-2002, 12:53 PM
Right. Something to keep in mind. You have to pick up a desoldering kit at at Radio shack and suck off the solder and resolder in the new one.
Ask warren about the details of putting a slug in there so that you can swap chips in and out. I didn't. I just soldered the new one back in.
If it starts, you did it right. If it doesn't...
so at least you'll know right away.
-kb-
Old 03-09-2002, 03:30 PM
Do you have a picture of your exhaust? Thinking of doing the same and would like to see your configuration. Thanks.
Old 03-09-2002, 06:23 PM
dickster's Avatar
does the chip get remapped to suit the application or is it one chip for all, straight off the shelf??
Rich
'86 coupe
"there you are"
Old 03-09-2002, 11:57 PM
Send a message via AIM to eurocarrera
Has anyone ever tried the "program" from the Racer's Group - located at Sears Point in California? They claim to be able to have a similar output as the weltmeister, and the chip can be re-programed each time a new modification is made to the engine. In all reality, wouldn't the engine need to be tuned each time your were to change the air filter (say to a K&N), or a free flow exhaust?
Bill Atkins
mrpeabody37@yahoo.com
1985 Carrera Coupe ROW - SOLD
Old 03-10-2002, 08:40 AM
dickster's Avatar
basically yes. i wouldn't touch a chip that was one fit suits all.
Rich
'86 coupe
"there you are"
Old 03-11-2002, 02:28 AM
