What is this part called?
There is a rubber bushing or some such rubber disk that goes between the piece which connects the steering rack to the front hub assembly. Name that part so I can order one for each side. Thx
Do you mean the tie rod bushing?
Finally looking it up using PET, its the ball joint. Need to see if just the rubber part is available, unless it is an assembly.
Try to find the part number and description there : Porsche 911 Parts and Accessories, Porsche 911 Parts
The ball joint doesn't come into contact with the steering rack - but whatever.
| All times are GMT -8. The time now is 06:46 PM. |
