tipe of shifter
Hello, how can I know what kind of shifter has my car.
I own an 67 912 and a 74 911
Old 05-21-2012, 06:13 PM
Same as gearbox type; 901 and 915 respectively ('72-'86).
Sherwood
Old 05-21-2012, 07:28 PM
thanks Sherwood, but how can I be shure that the gerabox is an 901 or 915? has it a specific number on housing?
best regards
Old 05-21-2012, 07:47 PM
best regards
Typically, the numbers on the bottom of the gearbox, along the casing seam. 901/XX, 915/XX. Compare your numbers with published tables in the various spec books.
The 915 has a slightly longer nose section than a 901, and when fitted into an earlier chassis (65-71), the sheet metal must be bumped out in various locations to clear.
Sherwood
Old 05-22-2012, 08:29 AM
Banned
Send a message via AIM to prebordao Send a message via Yahoo to prebordao Send a message via Skype™ to prebordao
Actually, I have a 915 with the old type of shifter... Maybe because it's a 4sp ?
Old 05-22-2012, 10:21 AM
The old style shifter is also used on the '72 with a 915 gearbox. Suggest upgrading to the 915 shifter. It's better, even with a 4-speed. My 911 originally came with a 4-speed ('69 w/901), but I've never run across a 915 4-speed.
Sherwood
Old 05-22-2012, 11:22 AM
Banned
Mine was built in oct 73...
Or that or was changed later, but it's definitely a 915 4sp. For the US only the 5sp was sent, I think.
So if i can change to the later style shifter will i notice an improvement ?
Old 05-22-2012, 11:31 AM
Best to drive a 911 with a 915 shifter and decide for yourself. YMMV.
S
Old 05-22-2012, 11:46 AM
Thanks sherwood, for all the info.
cadavieco
Old 05-26-2012, 03:47 PM
Banned
best regards
There' s a simpler way to find out. The 901 has 1st on left and down, 915 has it on left and up. Right ?
Old 05-26-2012, 03:58 PM
