Ride Height Adjustment '82 911 SC
I am trying to adjust my rear height down about an inch. I loosened the bolt closest to the torsion bar, then loosened the eccentric bolt next to it. Although I was able to turn the eccentric bolt, the radius arm did not move in relation to shorter arm coming from the torsion bar. They seem to be stuck together with some corrosion. Is there a good method to free them up?
1-in drop will require removal of the torsion bars completely and re-indexing them.
Ole Skool - wouldn't have it any other way |
So the eccentric is moving and the two spring plates are not?
If the eccentric is seated correctly this should not be possible. How far are you able to rotate the eccentric? |
porsher
they could be corroded together, try some liquid wrench or equiv and some gentle persuasion, remove the bolts altogether and gently jack up the hub
it may be at the lowest point already turn the eccentric the other way and see if it raises the spring plate
86 911 Race Car, with a few 993 bits in the boiler room 79 928 Race Car 88 928 Becoming a Race Car |
From a look at Wayne's book (free plug), it looks like you will need to remove the lower, rear bolt from the torsion bar cover. Otherwise, the torsion plate (or radius arm) will be held hard against the said bolt by the torsion bar and no amount of adjustment will shift it. Equally, you won't be able to measure the effect of your adjustment until the torsion plate is able to swing freely.
Hope that helps.
1982 911 SC coupe RoW moss green SSIs and M&K 2-1 muffler |
cycling has-been
73 911T MFI, 76 912E, 77 Turbo Carrera |
The plates should move relative to each other. Both the bolts closest to the torsion tube should be loosened, the lock bolt and the eccentric. The plates do tend to get corroded together, so you might need to persuade them. Rootmat was referring to a torsion bar adjustment, which is not applicable to your question. I think the max adjustment, with the spring plates, is about 1/2 inch up or down, assuming they started in the middle of their adjustment range. If you need an inch, you need to re-index the torsion bars. Maybe you could fudge it if your adjusted one side 1/2 inch up and the other 1/2 inch down, but that would be kinda ghetto.
Good luck.
Doug 79 SC Targa w/ ITBs, 2004 Cayenne Turbo |
cycling has-been
when I did mine- I had to get a 24", x 1/2" drive breaker bar (torque values are very high) and the thin Wilding combo tool/wrench from pelican to hold the bolt heads that are between the wheelwell and the spring plate. Bill K
Pelican Parts - Product Information: PWE-2436RHW
Northern Motorhead
Don't forget you have to unload the rear sway bar by disconnecting it from the drop link ...
Should make adjusting your spring plate eccentric bolt a little easier ! Cheers ! Phil
Cheers Phil 89 Coupe,Black,95 3.6 engine and the list goes on ... 1983 944 SP2 race car PCA #96 |
Removing the bottom cover bolt is not necessary to lower ride height. Would make raising it a little easier. If things were moving as they should simply loosening the 2 bolts (pinch and eccentric) would result in the TB rotating the spring plate to its lowest setting. Least it does on my recently rebuilt spring plates with never-seize applied.
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
Looks likes the OP got scared off.
