Peter Zimmermann |
08-01-2011 03:28 PM |
Originally Posted by motogman
(Post 6169346)
Peter... after your very informative post (7/27 10:17 pm) I have been trying to listen more closely to see if I have a 'problem' or not... my valves definitely need adjusted (it seems to me) as they clatter a great deal. The only time I hear something that might resemble a 'phat, phat, phat..." is when I launch in second gear and lug the engine a bit.
My current thinking is that this is not a tail tale sign but just the loose rockers and luging the engine.
However,... my question... when would the phat, pop, phat be most noticible?
The "pop, pop, pop..." is most noticeable when the engine is loaded, perhaps lugged, as in your second gear start. It can be worse on a cold engine, and is harder to hear, in the beginning, at higher revs. A long distance diagnosis is really difficult, but the noise will never be a "rattle," or irregular. It will have a definite cyclic quality, because you will hear only the compression loss, usually, on one specific cylinder.
Regarding re-torquing, that is not necessary on engines that have an aluminum crankcase, and are in sound condition. If the engine is a 2.7 liter, it's best to gently re-torque the heads, cold, at your routine valve adjustment interval. Properly installed case savers will go a long way toward preserving the torque of the cylinder head nuts, but even then they can loosen slightly.
BTW; here's a picture of the tool that I use (unfortunately I can't find the similar hex socket on which I've ground the shaft slightly to provide extra clearance for certain applications)...it's 10mm, made by Snap-on, and is 3/8" drive.
http://forums.pelicanparts.com/uploa...1312241096.jpg
