TSwede's Avatar
Will a SC Fuel Dist fit a 2.7s
Will it bolt straight on? They look similar... I need a fuel distributor and it will be easier getting a 3.0 one in these parts.
Any mods needed to do this?
TSwede
Old 03-09-2002, 02:35 PM
makaio's Avatar
According to my parts reference guide, they are a different part #. I couldn't find anything saying you could swap one for the other. I imagine they have different delivery rates and such (?).
Fire an e-mail to JW, I'm sure he would know if they are inter changable.
Old 03-09-2002, 05:29 PM
TSwede's Avatar
So....
what if I change it anyway? I am aware that they are a different part no. but they look physically the same - I'm wondering if anyone knows what will happen if I change it to an SC. I appreciate your point about different delivery rates - it might end up so rich I can't adjust it... Seems odd that they are a different part at al considering how adjustable the 2.7one appears to be.
Cheers anyhow.
TSwede
Old 03-10-2002, 03:46 AM
It should work....but I don`t know how well. I believe people swap them (3.0 to 2.7) to get around the Lamba circuit on the later SC`s.
Tinker
Old 03-10-2002, 07:56 AM
TSwede's Avatar
Question..
So I guess I'll be wanting one withour a Lambda circuit as well then. like an early SC - do you know what year they started?
TSwede
Old 03-10-2002, 11:28 AM
Why don't you just get your 2.7 distributor rebuilt. If you buy a used one (which you already have) there's no guarantee that the "new" used one won't have some other problem.
Try KMI Fuel Injection inthe UK for rebuilds.
Also make sure you actually do need a fuel distributor first.
If the car has some miles on it, then probably the injectors and o-rings also need work or replacing.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 03-10-2002, 11:32 AM
TSwede's Avatar
because...
I can't afford a rebuilt one at the moment
and...
It wil cost me approx £100 to get the fuel dist tested properly with the rest of the system - then If this is the problem I will have to buy one.. double cost
whereas if I buy a second hand one and it works I've saqved money that I don't have
If it doesn't work then the fuel dist I have bought must be OK and I can sell it on - no cost at all this way
Also the chances of the fuel dist I buy having the same problem as mine are extremely slim as no-one on this board appears to have had the same problem
Logic? - Well maybe to some. But cheers anyway
Regards
Tony
TSwede
Old 03-10-2002, 11:39 AM
