-   -   This is a repo Fuchs correct? (http://forums.pelicanparts.com/porsche-911-technical-forum/622085-repo-fuchs-correct.html)
rhart 07-30-2011 04:36 PM
1987 They are too perfect to be real. Does anyone recognize the maker of this wheel?
Thankshttp://forums.pelicanparts.com/uploa...1312072571.jpg
plumb4u2 07-30-2011 04:53 PM
that looks like a correct marking....any pics of the front?
shouldnt it have a part # marking also?
rhart 07-30-2011 05:13 PM
Thats why I think its a repo. Here is the other marking. I don't see a 911**** number on it and the wheels are way too perfecthttp://forums.pelicanparts.com/uploa...1312074798.jpg
http://forums.pelicanparts.com/uploa...1312074810.jpg
Joe Bob 07-30-2011 05:14 PM
Looks good to me.....look for a part#, like 901 or 911 or 951....
The triangle is the Fuchs logo.
Hodgey 07-30-2011 05:26 PM
I concur.....congrats
Neil
rhart 07-30-2011 05:28 PM
Thanks guys. I think maybe the 911*** number is under the brake dust. Guess I gotta do a better job of cleaning.
dentist90 07-30-2011 08:10 PM
http://forums.pelicanparts.com/uploa...1312085426.jpg
There's your Fuch fox right there.
WPOZZZ 07-30-2011 08:27 PM
Nah, they're fake. I'll give you $200 for the set.
J/K They look real to me as the fox head is there along with the part #.
dentist90 07-30-2011 08:29 PM
Your part number should be right above the fox... see mine:
http://forums.pelicanparts.com/uploa...1312086487.jpg
kidrock 07-31-2011 03:42 PM
dude, those are the real deal.
BTW, that's a darn nice looking cabby you have there.
dw1 07-31-2011 04:22 PM
"They are too perfect to be real." ?????????
Check out the number of threads on this board that discuss wheel refinishing and related topics and you'll realize that the wheels were probably just well cared-for and/or refinished by Al Reed, or another quality refinisher, or by the PO.
It is also possible that aggressive abrasive cleaning of the inside of the wheel (e.g. to remove brake dust staining) could have degraded the clarity of the part number. But the remaining markings sure look real to me.
Seeing the red calipers also indicates that someone spent a lot of time on the area inside the wheel wells.
Very nice look cab, btw.
-dw
'87 black/black sunroof coupe w. f/r spoilers, fabspeed euro premuffler, dansk 1-in-2-out (84mm), sw 93 octane chip, euro ride height, bump steer kit, rear bumperettes deleted, CRD-220, etc.
Drisump 08-01-2011 05:38 AM
The weight itself (or lack of) is normally a dead giveaway, even without seeing the factory markings...they're the real deal.
smunczen 08-01-2011 05:55 AM
Sometimes you get lucky and find a set that somebody took care of.
70SATMan 08-01-2011 07:51 AM
Joe Bob, the triangle is not a Fuchs logo.
It is the logo for an OEM part built for Porsche. You will find that logo on original Bosch lenses, Koni and Boge struts, etc.
Joe Bob 08-01-2011 08:00 AM
Yeah...went and looked again. The triangle AND the foxhead are a good sign.
red 2.7 08-01-2011 09:16 AM
"Fuchs" means fox in German hence the fox logo. As real as it gets,lucky you.
rusnak 08-01-2011 10:02 AM
The triangle is the Porsche logo. It's the stylized "P" that appears on everything from tail light lenses to distributors. Since Porsche owns the dyes that Fuchs uses to forge the wheels, the stylized P makes its appearance on all real Fuchs wheels.
Those were apparently refinished, so it would probably be normal for the markings on the back to be diminished in clarity and depth. I'd value them at slightly lower than original untouched Fuchs.
