Head studs and oil leakage
I'v taken off all 4 of my valve covers to analyze my head studs. They look good visually, I poked at them with a screwdriver to make sure they aren't loose, and they passed that test too. I am trying to diagnose popping in my exhaust from my carb conversion - and I read broken head studs can be one of many causes. It seems they are fine. Tomorrow I'lll check the valve clearances. (previouslly checked mixture settings and exhaust system for leaks)
I also read that broken head studs can cause oil on the fins underneath: a flashlight examination can be done of the areas where the cylinders and cylinder heads join. Those areas should be dry and clean. If there is a black, crusty layer that appears to be burned oil, there is a chance that the engine has one or more broken head studs where the buildup is the heaviest
Which you can see in the picture below, I have plenty of that. Should I be checking my head studs even more closely or is this just normal leakage over time with seals failing?
DD summer/winter: 2000 Boxster S
DD spring/fall: 914-6 w/ 3.0L SC Dual Webers (For Sale)
http://imgur.com/a/k0Wtl - My 914-6 Build/Project Story
Old 07-31-2011, 05:55 PM
When you look at the exhaust side studs, look at the rocker shafts, make sure theyre not moving off location,..major oil leak if they do.
Bruce
Old 07-31-2011, 06:03 PM
Cylinders with broken head studs.......
This is the picture of the cylinders #1-2-3 with broken dilavar head studs.
With the cylinders removed:
This is an example of a neglected engine that was driven for a while with several broken cylinder head studs. The lower head stud closest to the crank shaft pulley for cylinder #1 broke off only during dis-assembly. Notice the amount of dirt accumulated due to oil leak/s.
Tony
Old 07-31-2011, 06:46 PM
That oil leak looks like it comes from the base gaskets. I don't think you have much of a leak from the heads to cyliders seam. If the headstuds aren't loose or broken, don't worry about it until you can't stand the oil leak anymore.
Old 08-01-2011, 09:15 AM
