Smile Wooden ramps to elevate car
Greetings,
Over time I've noticed pictures of garages where ramps have been built to drive up onto, elevating the car so that (I assume) it's easier and roomier to crawl underneath. I'm wondering if anyone would like to share their experience with building such things as I think I'd like to build a set.
Thanks,
Jack
Bassjack
85 911 Targa
Old 08-02-2011, 01:58 PM
Banned but not out, yet..
RSBob's Avatar
I just hope who ever replies has a good attorney.
Old 08-02-2011, 02:08 PM
300hp 1800lbs is the goal
pksystems's Avatar
What is your house made of?
The '66 912 Bastardization project has begun.
Note to PO's: LAY OFF THE FREAKING BONDO!!!!
The science was settled: Earth was flat.
Galileo : Flat Earth denier.
Old 08-02-2011, 02:11 PM
Most probably you have seen the ramps that are placed to accomodate a scissors lift.
Old 08-02-2011, 02:14 PM
pksystems's Avatar
DIY - Homemade Wooden Ramps For Your Car - Page 2 - Bimmerfest - BMW Forums
Scroll down, there's a bunch of pictures. You probably saw the Mustang Cobra pics that are on that page.
Wood will hold alot, if engineering properly. Do you really want to waste that much room for those things tho?
I'm probably going to make some solid ramps soon to do rust repairs on the jack points of my DD.
Old 08-02-2011, 02:28 PM
As stated above, wood will hold up anything if engineered properly. We've ramped 200 ton working cranes on jobsite with engineered hardwood ramps. The downside is weight, if you plan on keeping them in one spot all the time wood will work just fine.
Old 08-02-2011, 05:29 PM
Danny_Ocean's Avatar
I made these (modified a little for strength). Used them with an F350 diesel dually, no problems:
ramps2
Sue me.
Old 08-02-2011, 05:39 PM
What I'm after is a ramp that would span the front and rear wheels providing four to six inches of lift...just enough clearance to allow for more access under the car. I think it could be accomplished using two or three 2x10s screwed/bolted together, etc.
Bassjack
85 911 Targa
Old 08-02-2011, 05:58 PM
rnln's Avatar
Bassjack,
I did a set with 2"x10" or maybe 11". I don't like the "box" idea because I am a chicken. We used to have a set of metal ramps. My cousin drove his Celica on them and bent them. Of course, because he didn't align them right, but still.
If you search on Scissor lift on this board, you will see many people have them along both sides of their scissor lift. I made similar but 4 pieces, each at each wheels, so that my car would be around 3" raised.
Fat butt 911, 1987
Old 08-02-2011, 06:21 PM
I made some ramps out of 2x pressure treat. They're stronger than any plastic ramps you'll find and probably most steel ones. I made them because I used to have a Miata and couldn't find any ramps with a low enough angle.
I plan on making some wood platforms for the 911 to facilitate jacking the car up.
1986 911 Carrera Coupe
2016 VW Golf R
2008 Toyota Highlander (given to kid)
2021 Kia Telluride
2020 BMW R1250RS
Old 08-02-2011, 07:29 PM
El Duderino
tirwin's Avatar
Why? A man cannot be responsible if another man is eat up with dumb@$$.
Old 08-02-2011, 08:11 PM
"farking Porsche hero"
Rich Lambert's Avatar
Here's some I built.
Rainy weekend ramp project - The Garage Journal Board
Rich
'66 911 #303872
'07 Cayman
'17 Macan
'58 Land Rover S2 88"
Old 08-02-2011, 08:20 PM
RSBob's Avatar
Brick. Next sarcastic question please
Old 08-02-2011, 08:58 PM
RSBob's Avatar
ramps2
Sue me.
man, the attitude around here.
I have almost identical ramps, just made from plastic rated at 4 tons, almost the exact same design. Nice DIY
Old 08-02-2011, 09:03 PM
RSBob's Avatar
Originally Posted by Rich Lambert View Post
Rich,
You missed an opportunity to take a shot. And after all the ones I have given you over the years...
See you at the upcoming dinner. Very nice ramps btw.
Old 08-02-2011, 09:14 PM
Immature Member
dentist90's Avatar
I made some too, just to make oil changes a bit easier.
1984 Carrera Coupe = love affair
1997 Eagle Talon Tsi = old girlfriend (RIP)
2014 Chrysler 300 AWD Hemi = family car
"Lowering the bar with every post!"
Old 08-02-2011, 10:17 PM
AutoBahned
RWebb's Avatar
I have some sets of 6" timbers that I shove under there after I jack it up.
make sure they are nice and wide...
Old 08-02-2011, 10:40 PM
T77911S's Avatar
for those in doubt, look at your 16ft garage door openings, what do you think is holding up the rafters+plywood+shingles+snow (for those up north).
i have been thinking about something to drive the car on like above. but to make it worth while for the size (storage) and weight in order to make it strong. plus, too make it high enough without tipping over to make it usefull.
something like above would be great for doing suspension adjustments, just remember to roll the car back and forth so it can settle between adjustments. if you have scales, you could make a recess for the scales to fitt into so you could just drive right onto them. IE, the top of the scale would be the same height as the ramp.
when my car was scaled, it was put on a lift then set down on the scales that one on these short stands, probably not much taller than the ramps above. then ramp would be much easier.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 08-03-2011, 05:37 AM
nineball's Avatar
a pair of 2x10 screwed together and an old set of steel ramps cut down.
- He gave his father "the talk"
- Once while sailing around the world he found a shortcut
- He taught a german shepard how to bark in spanish
He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends.
Old 08-03-2011, 10:16 AM
Thanks to all for the suggestions. Rich, what you posted in the link is exactly what I had in mind. Jack
Bassjack
85 911 Targa
Old 08-03-2011, 11:15 AM
