1989 911 Carrea Gear shifter loose and won't engage
Hi...my 89 Carrea gear shifter began to become very loose and I couldnt access 1st or Reverse. The only gear I ended up being able to engage somehow was 4th to drive home & to the shop. Now, I can't engage any gear as it just flops around, although the clutch has about 600 miles on it and was grabbing but smelling like burning when I brought it in.
Any thoughts and average cost? Something with the gear box maybe?
Old 08-04-2011, 01:41 PM
Pop off the plate over the tunnel on the floor behind and between your seats. CHeck the to see if the coupler is loose. If so, an easy fix.
Christopher Mahalick
1984 911 Targa, 1974 Lotus Europa TCS
2001 BMW 530i(5spd!), Ducati 900 SS/SP
2006 Kawasaki Ninja 250, 2015 Yamaha R3
1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750
Old 08-04-2011, 01:52 PM
Thx...you think the burning smell was because I was driving from a stand still into 4th gear?
Old 08-04-2011, 01:57 PM
Porchcar guy's Avatar
That is a most likely conclusion..Hopefully it is only the coupler and as said above, an easy fix
15 year PCA member
1972 911 E Coupe - gone now
1987 Mazda RX-7 2+2 - still cooking
Swift DB-1 FF & Swift DB-3 F2000 -not forgotten
1979 911SC 3.0 & 2000 Camaro
Old 08-04-2011, 02:13 PM
thanks... i had this happen before with a truck and it was the gear box that went bad.
Old 08-04-2011, 03:15 PM
m110's Avatar
If not the coupler, might be the cup/ball mechanism at the end of the shifter...more likely on a 915 than a G50 but that's where I would look next.
1988 Carrera Coupe
Old 08-04-2011, 06:27 PM
Pre Registered
tchanson's Avatar
Agreed. Sounds like the coupler to me, but if that's OK check the ball socket next. These are plastic and can and do crack/disintegrate over time on G50's as well.
Parts 10 and 11 on the diagram below:
Tim
Old 08-04-2011, 06:53 PM
