Timing Chain housing Covers(update kit)
Wondering if anyone has any ideas about getting timing housing covers off for oil fed tensioners. Figured they would pop right off but they are bound up around tensioner hole. Housing is so thin I don't want to break it or damage it. I'd imagine the best way is to use a torch and heat it alittle. Any other ideas? Steve '81SC
Old 03-10-2002, 01:31 PM
makaio's Avatar
They will take some effort. Just use constant pressure and they will pop off. Make sure to use new o-rings on the tensioner for the cover plates. Otherwise you will be doing it agian.
Old 03-10-2002, 01:50 PM
a light downward wack with a rubber hammer on the top seam gets them parted.
206 637 4071
Old 03-10-2002, 03:58 PM
Cool
Thanks alot guys - I got them off, just pried them off slowly. After alittle effort they popped right off. Steve '81SC
Old 03-11-2002, 06:01 PM
