pryord's Avatar
Fog Light Dianosis?
First one fog light went out, then the other. I replaced the bulbs and fuse, but they still do not work. Is there a way I can check the relay before buying a new one? Any other ideas?
Thanks,
Old 03-11-2002, 10:39 AM
pryord's Avatar
..and that's diagnosis, right?
Old 03-11-2002, 12:35 PM
81SC's Avatar
Dave if you run 12v through pins 86{positive} and 85{negative} you should have continuity through pins 30 and 87 on the relay.Can you just swap one of the other relays to see if the lights work.
81SC Coupe
Tony Kart/Yamaha
Old 03-11-2002, 04:03 PM
