Red face im in a pickle
so i took my 82 sc to a very reputable local mechanic, he told me it would be a grand to fix it, im in over my head just getting my dream car i take it to a neighborhood shop , where i have seen several 911's through out the years, he said he could do it for 600. well needless to say it ran worse than before. i took it back to the PM and her sprayed carb cleaner from a can with a straw that was pinched off slightly so as to not make a mist and almost every one of those intakes were leaking at the gasket. the guy that did the work said he did a smoke test and is showed a slight leak coming from the air box, I told him to just do the job i payed him for and make it so that there are no vac. leaks around the intake gaskets.
Old 08-05-2011, 07:01 PM
crustychief's Avatar
Are you saying you took it to a reputable Porsche mechanic first, then took it to a non reputable mechanic?
A nose heavy airplane flies poorly, a tail heavy plane flies once.
Old 08-05-2011, 07:07 PM
plumb4u2's Avatar
No disrespect but is there a question here or are you just venting
If you would like some help you should explain the problem
Justin
84 Carrera Targa
98 F-150 4x4
Old 08-05-2011, 07:10 PM
efhughes3's Avatar
If you take as much time talking to your mechanic about your issue as you did describing your problem here, apparently for advice, you probably got your money's worth.
What's the point of this thread-venting?
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 08-05-2011, 07:12 PM
efhughes3's Avatar
Captial letters are nice when starting sentences too.....
Ed Hughes
2015 981 Cayman GTS
Old 08-05-2011, 07:14 PM
pete3799's Avatar
So what did you bring it in to get fixed?
Pete
79 911SC RoW
.wow did i just log into the wrong forum
mostly not so critical here, mostlY
Old 08-05-2011, 07:17 PM
RRico's Avatar
who in delray did the the work on your 911?
the intake gaskets
Old 08-05-2011, 07:30 PM
can't follow this guy, need more / better info.
73 911 T MFI Coupe, Aubergine
Old 08-05-2011, 07:34 PM
the intake gaskets are leaking after i took them to get replaced.
Old 08-05-2011, 07:39 PM
Hmm, no disrespect, maybe it's time to fine a mechanic that you can trust.
Old 08-05-2011, 07:45 PM
live and learn i guess
Old 08-05-2011, 07:53 PM
kramer747's Avatar
A grand is pretty much normal when taking your P-car to a mechanic. Sorry. Kind of like going to Costco and not getting out for under $100.
Old 08-05-2011, 09:34 PM
