84 Pedal Assembly Help
Removed the pedal assembly today to have rebuilt and new spring installed. I had a hell of a time getting the allen bolt for the support bracket out. Is there any other way to get the support bracket out from the other end?
I here you that allen bolt was a ***** but I got it out and back in with a little patience so just take your time....don't know about removing bracket from other side I didn't want to go there, you should be able to get bolt back in with out to much trouble
Justin 84 Carrera Targa 98 F-150 4x4 |
That's what I figured just wanted to know if the support bracket was able to be accessed easier from the top.
