Flatbedding to the mechanic - SC saga begins
So the '78 SC 3.0 is being flatbedded to the mechanic today. Please say a prayer.
Last night it didn't want to start - turning over slowly. After about 6 cranks it reluctantly started and ran. I noticed what sounded like excessive valve train noise from under the engine. The engine sounded like it was laboring. 30 seconds into running the engine starts with a jet-engine-loud grinding noise. I jump to the ignition switch and turn it off. The engine comes to an abrupt, grinding halt. I call the local Porsche guru and he arranges for the flatbed. I will document the process from here on out and provide updates to the group. Any thoughts on what sort of catastrophe I am facing? Known Facts: Completed valve adjustment last month Oil change complete with valve adjustment Oil level good Oil pressure good Fresh trans fluid last month New alternator last month - unit good including bearings
1978 911 SC Targa Metallic Bronze and Cork SSI's and Danske Sport Muffler SS Lines, Momo Steering Wheel, H4's |
flatbed
ouch
1978 911sc cpe 1986 944 N/A sold to pelican 1965 series 2a 88 landrover sold 1964 series 2a 88 landrover sold 1988 944 white. sold |
You're probably not dealing w/ a tune up so if you have to get into some serious engine work is your mechanic up to the task? Or is this mechanic someone you've had a long trusted relationship with?
I hope it's not as serious as it sounds...
Mitch Leland "03" 996 C2S-LS3 V8-480 HP "84" 911 Turbo Look-Sold w/ found memories |
Sorry, I just read the initial post and you mentioned good alternator bearings. Are you sure they are good?I wonder if your alternator gave up the ghost? That would explain the slow cranking. And the "Jet Engine" noise could have been caused by the bearings disintegrating.
Just a thought.
Christopher Mahalick 1984 911 Targa, 1974 Lotus Europa TCS 2001 BMW 530i(5spd!), Ducati 900 SS/SP 2006 Kawasaki Ninja 250, 2015 Yamaha R3 1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750 Last edited by CCM911; 05-27-2011 at 09:06 AM.. Reason: Correction. |
Let's HOPE it's ONLY alternator-related!!!!!!!!!!
BEST! Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
abit off center
How did you run it and how did it run at your last shutdown?
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
Good luck. Hopefully the alternator as stated above.
S.o.s.
Arrived at the mechanics ok. Talked a few minutes and he started her up. Hard starting, as if the car was having trouble turning the engine over. Started on 4th crank.
Ran for almost a minute before the loud grinding and laboring started. Turned it off. Mechanic said he thought it was the fan. Took the fan off and discovered it was in fairly bad shape and not fitting quite right. Put on a new belt, adjusted the shims, tightened the fan down. PROBLEM FIXED! Drove the car home. BAD NEWS! I start the car again a couple hours later and after running for a minute the grinding and laboring starts again. So I figure somehow the fan must be messing things up. Remove the fan and belt and start the car. The loud grinding is present immediately. I swear white smoke was coming out of the exhaust too. The sound appears to be coming from below where the alt fan is mounted. Has anyone experienced this? Thoughts?
I would stop trying to start it personally. I would drain the oil first and look for pieces, then I would pull the rocker covers and the chain box covers and try and see what's going on.
2021 Model Y 2005 Cayenne Turbo 2012 Panamera 4S 1980 911 SC 1999 996 Cab |
Retired Member
+1
1982 911 SC Targa - Rosie....my Mistress. Rosewood Metallic on Dark Brown and Black. Long distance road warrior and canyon carver. A few mods - a little interior, some brakes, most suspension and all of the engine. |
Perhaps you can record a video for us and put it on youtube.
james www.gruppe9autowerks.com Its not how fast you go...its how you go fast |
Wow....does your mechanic work on these cars regularly? If not, please find one that does so further possible damage to your engine does not occur.
I too would not start the car again until the source of the grinding is located and resolved. Then again, depending upon how many times it has happened and been run....the damage may already be there. Best wishes for a simple fix with no real engine damage.
'71 914-6 #0372 '17 Macan GTS |
Aaron at Flat Six is the man. The starter gear was kicking out when the car was running. Replaced starter and problem fixed!
Nothing better than a happy ending!
1983 Porsche 911SC - Arrow Blue lightweight '74 Carrera look http://forums.pelicanparts.com/porsche-911-technical-forum/498568-overdue-intro-sc-hotrod-project.html |
Retired Member
Perferred over pulling the engine apart.
My starter did that not too long ago. I'd worry about what caused it. Mine was caused by a bad ignition switch that was not springing back from the start position. I hope your car is fixed now, but I'd be wary for a while.
Rex 1975 911s and 2012 Range Rover Sport HSE 1995 BMW R1100RS, 1948 Harley FL |
