| bob deluke |
08-07-2011 05:26 PM |
no start condition
I have a 77 targa, 2.7L motor, all original. Having a problem with a no start situation after I pulled engine/tranny for rebuild of 915 trans. Did some rewiring that p.o. cobbled up. Got everything ready to go, turned ignition switch on, nothing. Did all cursory checks, electrical including 14 pin out connector. I bench tested starter, worked fine. Installed, nothing. Removed starter again, disassembled, cleaned solenoid, bench tested again, worked fine. Installed, no start. Have voltage at terminal 50 and 30 with key in start position. Solenoid is very hot to the touch. Battery checked for proper voltage and had it load tested, no apparent problem there. Could I have a bad solenoid switch on starter?
